what carb for my set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 07:25 PM
whats up guys !!! i have a a 350 bored over .80 with a 507/510 lift cam....stock heads that have been redone and milled down... from this can someone recommend me a carb size ...the car will not be a daily driver but will be driven ! i guess im looking for street/strip!
Old 08-06-2012, 08:48 PM
if it is a standard I'd suggest a 750 dp holley if it is a automatic I'd drop a 750 vs. dp=double pumper , vs= vacuum secondary, and a trick kit in which ever you deside
Old 08-06-2012, 10:08 PM
Banned
"Heads" can mean anything depending on what heads anything from a 500cfm to a 800cfm carb would be appropriate. Also, what came, intake, compression, and exhaust?
Old 08-06-2012, 11:10 PM
vinniekq2's Avatar
750 double pumper. How did you bore the block 080?
Old 08-07-2012, 09:40 AM
Yeah??????
Old 08-07-2012, 10:59 AM
Banned
not .080 but .80... a 4.8" bore sbc. that's pretty damn interesting.
Intake and Carb set up zachinnis Engine 6 10-15-2011 10:54 AM
How Do I Bulid A Two Carb Set Up buggmann Engine 7 08-03-2008 11:17 PM
hot to set carb 82c10 Engine 2 01-13-2006 09:05 PM
opinions on best carb for my set up dion Engine 16 12-22-2003 11:54 AM
What if I set up a carb on my rebuild... CamMan Engine 1 12-20-2003 08:55 PM
