What carb should I get for my 350 sbc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 11:18 PM
Hello I have a 350 sbc with all stock bottom end/ valve train, the only thing aftermarket is the edelbrock intake, headers, and currently a drained 650 holley. The holley needs to be rebuild or replaced and I would rather go with something with vac. secondaires, anyone have suggestions for size and brand? Thank you.
Old 03-13-2012, 09:56 AM
Canzus's Avatar
a red wool sock on his dinger
Is it a spread bore manifold? If so, Q-jet would be my first choice...
Old 03-13-2012, 10:07 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
the cheapest is the shiny holley 600 . they sell more so they are less. the ideal would be a 390cfm holley.
Old 03-13-2012, 10:14 AM
Edelbrock #1406
It is a 600cfm.
The Edelbrock has no gas above the gasket levels.
SO no leaks like a HOLLEY.
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Best carb spacer style Edelbrock carb truckboy61 Engine 2 07-24-2011 09:18 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
