What Carbs On Your 350? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-13-2010, 03:21 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Back to the orignal question. I ran a 670 avenger also and was very pleased. This was on my 355. And i really like the 3310 vac secondary also always had good luck with it as already stated.JMO
Cole
  #32 (permalink)
Old 10-13-2010, 03:27 PM
355ci's Avatar
Originally Posted by eloc431962
So your speedo reads 145 and you are still pulling hard Hummmm!!!!!!!!!, how fast are you going then? You think and do you think your speedo is correct at that ?
Cole
I dont know.I know that the 86 IROC-Z did 150mph stock. WITH a 190hp 305ci. An a TPI that would only rev to 4500rmp. These are GM and ROAD&TRACK numbers. I dont know if the speedo is right, I dont get stopped on the highway. I run 75-78mph. Speed limit is 70mph
  #33 (permalink)
Old 10-13-2010, 03:32 PM
sqzbox's Avatar
My pipes are my music
I had an 88 formula with a 305 and 700R4 and the rpm at speed was the same as yours, 70 mph in 4th at 2000 rpm converter locked up with the same size tires. Rear end ratio was 2:73:1.
  #34 (permalink)
Old 10-13-2010, 03:34 PM
355ci's Avatar
Thank you SQZBOX
  #35 (permalink)
Old 10-13-2010, 04:04 PM
355ci's Avatar
Huh say what i am running a Holley 830 p Series carb and it was a official nascar carb at one time anyway. Hummmm has something changed? Where you at Cobalt ?
Cole
OK sorry. THE BUSCH series run 575hp limit @390cfm your carb is NEXTEL CUP 890cfm limit some series run 500cfm.But 575hp from 390cfm! SOMEBODY TELL ME HOW?
  #36 (permalink)
Old 10-13-2010, 05:09 PM
Originally Posted by Madmax305
Huh, say what! I did not know that was possible.
correct me if im wrong but didnt the 440 come with a 6-pack? mabye its 3 390cfm carbs.
  #37 (permalink)
Old 10-13-2010, 05:12 PM
Originally Posted by 355ci
what size is it?750-800cfm?hows the low end idle-3000rpm,mine has hesitations and flat spots.
Idk what CFM it is, all i know is that it was off a 454 BBC from an RV. and when i rebuilt it i think it had jet size 72's in it? some where in that region.
it had a little bobble with the stock exhaust manifolds on it, but after i installed the headers its great, just keeps pulling and pulling.
  #38 (permalink)
Old 10-13-2010, 05:27 PM
I have had different carbs over the years between holley, edelbrock and barry grant. I had both good experiences and bad with all three carburetors. Nowadays I have learned to take apart your carburetor and look it over and clean it and maker sure its safe to put on.
Bottom line I prefer holley style carburetors as I feel they are easy to rebuild and have more options to fine tune them as compared to edelbrock. I like the simplicity of the edelbrock carbs to do basic tuning wise but for anything performance I like holley style hands down. Reason I say holley style is I have a proform holley style carb on my other truck and it runs excellent.
I also have a holley 1850 600 cfm carburetor on my everyday driver and one shot of gas and it fires right up and makes my 350 with my other parts run like a raped ape. Have read good things about Q jet carb but have never used one. There the best for fuel mileage from reading about them.
Eric
  #39 (permalink)
Old 10-13-2010, 05:33 PM
355ci's Avatar
Eric
Well put eric, My carb exprerience has been the same
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Need Opions On Head, Carbs And Cams on My 74 Nova 350 Novasthefirst91 Engine 45 06-05-2010 08:03 AM
Centrifugal advance DENCOUCH Engine 7 05-07-2010 06:39 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
