Carb I perfer: Rochester Quadrajet.
Why I perfer it: Small primaries make for excellant fuel injection like sensitivity throttle response, great low end torque and fuel economy. Massive secondary`s provide all the flow that`s needed for wide open throttle blasts. Secondary`s opened up sing a distinctive tune. Easy to adjust, easy to rebuild, easy to modify. Float you set once and forget it. A bit harder to tune but worth it. What I don`t like about Quadrajets: Small float bowl, so you gotta get creative. Automatic chokes that just about never work right no matter how perfect you set them. Leaky fuel wells you gotta Peen with a hammer to make them stop leaking. Why I don`t like Holleys: very cheaply made with next to no quality control. Got tired of having to fix them right out of the box. The Holley Spread, made as a Quadrajet replacement is a complete piece of junk. I could go on but the post would become a book. Why I don`t like Edelbrocks: Rear entry fuel line, I don`t like running alot of fuel line over a hot intake, it looks bulky and just gets in the way. Praying you get it right trim down metal tang to adjust secondary opening rate. (still shaking my head on what genius came up with that idea) Why I Don`t like Demon carbs: I had to take it off countless times and fix what the factory did wrong. Road Demon Jr I had was next to impossible to adjust the front float. Had to clean out all the passages due to them having metal shavings in them from the CNC operations. Had to sand down the base plate due to the secondary butterflies making contact with them causing them to freeze closed. Down leg boosters are completely worthless and made for lazy throttle response on the primary side. So there it is. Each carb has pro`s and cons. However, I found the Quadrajet had the best throttle response and overall best performance. So I work around there short comings. |
Love The rochester Quadra-Jet
Just rebuilt one from a BBC 454 and put it on my 350 pontiac and fire try fired up and has run great ever since. Only thing i dont like is trying to find the right Bimetal spring for the choke. |
Not sure what you meaning by how much CFM im using, but i have never felt like i need more, and ive had my foot into it many times. Should mention that im using a 50CC accelerator pump (made a huge difference, way more throttle response, but the 30CC was doing it job just fine!) and a yellow secondary spring. I used to have a Speed Demon 650CFM, NEVER will use a Demon product again, had better luck with a Holley spread bore that was sitting on the shelf for 20+ years |
my car shifts at 5800. i would guess my red line is like 6200-6500rmp but i never see that. at 5800rpm and 90% volumetric effeciency the calculator says 536cfm 595cfm @ 100%.I will get a 670cfm when i get gears,and 2400-2800 stall. yes the 50cc pump made a big difference in my 600cfm
The Quadrajet is a "Air Dam" carb, meaning it feeds what the engine demands.
However, if you notice, all carbs do this, they are fuel metering devices and that`s what they do. Some are just more precise than others. However, if you get into CFM formula`s you`ll notice the CFM on the formula is far lower than what`s already on the car. Like in some cases a hot 350 only needs 585 cfm. But if it`s ran with a carb that small upper RPM performance suffers. So I wouldn`t be worried about formula`s as what they say and what the engine runs best with is a world apart. Quadrajets are rated at 750 and 800 CFM. However, if the engine never demands it, it won`t give it. Another thing to consider is GM had horsepower restraints to go by, so they would limit the throttle opening on the secondary`s to 70 and 80% but it`s easy to mod it to 100%. I played with a Holley street avenger on a friends car. It replaced a older Holley 650. According to his 1/8th mile drag strip slips, it ran the same time and mph it always did. When I drove the car it didn`t feel any different to me either. It was somewhat easier to work on. |
but yea it runs like a dream, and i just finished all of the choke mechanism and its all working pefectly. |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| Need Opions On Head, Carbs And Cams on My 74 Nova 350 | Novasthefirst91 | Engine | 45 | 06-05-2010 08:03 AM |
| Centrifugal advance | DENCOUCH | Engine | 7 | 05-07-2010 06:39 PM |
| 348 or 350 delimma | 62ImpalaSS | Engine | 12 | 05-17-2006 11:03 PM |
