What Carburator - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2004, 11:57 AM
airman_turtle's Avatar
What Carburator
im trying to figure out what carb i should go with. i am getting drawn to the Holley Avenger Series. Currently i have a 600cfm holley 4bbl and i know it is two small. Im unsure whether i should get the 670, or 770 avenger. They say the 670 is for 300-400 hp and the 770 is 400-500. Im not sure where i stand. The things that matter are...
Comp Cams - 520 intake lift, 490 exhaust.
2.05 intake valve and 1.60 exhaust
headers and 2 1/2 in dual exhaust
350 bored .040 with 10.5:1 compression
Edelbrock Performer Air Gap (want to get a Performer RPM though)
Auto tranny
Old 09-20-2004, 12:14 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
670 is plenty
K
Old 09-20-2004, 12:17 PM
k thanks
Old 09-20-2004, 02:55 PM
stepside454's Avatar
Airman, how much RPM does the motor see ?
Old 09-21-2004, 07:35 AM
5800-6000 max
Old 09-21-2004, 07:39 AM
Yep, what Killer said, out of those 2 the 670 is more than plenty
Old 01-31-2005, 07:38 AM
ok, what if i wanted to use a demon? i like those as well, but i know they really under-rate them. would i go with a 575 or 650 cfm?
Old 01-31-2005, 04:30 PM
650 would be perfect
Old 02-02-2005, 01:58 PM
Technical Support Barry Grant
650 Vacuum Secondary Speed Demon P/N 1282010VE.
Old 02-02-2005, 02:43 PM
Mighty Mouse S-10's Avatar
Cleverly disguised as grownup
Last journal entry: Hollman & Moody
I'm currently running a 770 Avenger on a similarly built 350. I started out with a 600 edelbrock, but it had no top end.( above 5000 rpm) When I changed to the 770 I lost a little off the bottom but the top end really came to life.( pulled hard to the 6000 rpm rev limit) So now I'm looking for a deal on a 670. I like the Holley carb, but if I can get a deal on a Barry Grant 650 I would definitely give it a run. I'll be curious to know which way you go and how it comes out.
Old 02-02-2005, 03:04 PM
Mighty Im really surprised 600 isnt enough for a 350 to 5000 RPMs, maybe there was a tuning issue. I built a 400 for a buddys truck, its got a 600 Edelbrock on it, it pulls to 5K without a probem. Ive got a 770 on my 454.
Old 02-02-2005, 06:39 PM
Maybe a Holley would have performed better than the Edelbrock? The cam is 465/488 224/234 with 1.6 roller rockers on ported and polished Bowtie heads with Manley race flows. Headers and Flowmasters, so it breathes pretty good. Like I said the 770 is to big so maybe a 650 or 670. I've been looking at the Barry Grants but they are a little steep for my wallet.
