My guess is a bad batch of wire from the manufacturer. There had to be some sort of strong oxidizer present to do that much damage and as you surmise, normal wiring doesn't get exposed to that. Battery leads do with sulfuric acid fumes constantly bathing their ends. The factory must have left an acid wash on the copper or some such. I wouldn't worry about it.
First time I have seen this happen and it sure had me stumped for a while, I feel lucky I found the problem before tearing apart anything else. I can only assume that this is the reason the original pump quit running but that is no loss since I have always needed to change back to a factory tank and an external pump. This is in a 65 Mustang that had a modified 87 Mustang gas tank with the in-tank pump and the 87 wiring harness for the pump. The tank looked ok but obviously not stock and only had about 11 gals capacity so as I said I needed to change it anyway and this got me in gear to do so, I just thought maybe I had done something wrong several years back when I did the original EFI conversion that caused that corrosion problem.
I had a similar problem with a coil wire on a Bronco I could not find out why it kept stopping. Scan tool said that the primary coil wire was bad but when I checked it with a volt meter it checked good just like what you had.
I connected a bulb to the wire and the voltage dropped to about 3 volts. Next time you encounter this kind of problem put a load on the wire and then check it. A small battery checker will work good for this just add a small load 20 amps and watch to see if the voltage drops. I volt meter won't tell you if a wire is bad unless it is broken in half or has a dead short. |
Doc here,
Was this a Flat ribbon type cable ? Or a Branch circuit of individual run wires in a bundle? Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Since all the others in that plug was fine I just cut the wire on both sides of the plug and installed a spade connector been working like that for 10 years now. |
No, I wasn't ..But I know how the EECV 1 and 2 plugs up , and they are problematic for water and corrosion if left to their own devices..over time A Volt METER will always tell you what the DROP is..It is the test parameters that determine if you are going to see it.. A Corroded wire or partially open wire will will look fine at 12 volts and ground pulling 1 ma..as will a coil with a ballast will read 12 volts with the points open..the coil is not loaded..close the points , load the coil, the ballast will limit the output to 6 to 9 volts..which is the CORRECT load for that.. So you have to know what parameter you wish to see when testing, for an accurate answer. Doc
This was the 14 ga wire that runs from the fuel pump relay to the inertia switch and there are only two wires that run into the switch plug. If it makes any difference these wires are bundled together (tape wrapped) to form a cable that contains all the wires running to the back of the car, tail/brake lights, etc.
No...I was talking about the WHOLE rearward harness.. Some Factory outfits (like 70's Midsized GM for one..)used a FLAT RIbbon TYPE of cable from the front to the rear...looked a Computer hardrive cable..and ran it under the carpet/Rear Seat.. THIS type Cable can not (successfully ) Be soldered , or Crimped..along it's length..It is made from some aluminum Alloy AND is very THIN..like 5 or 6 strands of Brittle wire..If you try to solder it, it just balls up the solder, and if you try to crimp it..It just breaks..) like those "Old" headphone " wires years ago.. Sounds like WHEN the wire Went into the Copper Coating Bath at the Factory, they omitted the neutral Bath next and went straight to packaging! Doc
The other wires look ok so I guess the problem is solved now. I made a mistake earlier when I said it was the wire to the inertia switch, it was from the relay to the pump, don't know what I was thinking but I guess it makes no difference anyway. That's the kind of problem that can cause real headaches because it seemed as if I was getting power and if I had not of checked it while it was under a load on the pump I probably would have spent the whole afternoon tinkering with the pump and relays.
Oldred, Whenever I am checking something that draws quiet a bit of current I keep an old style(not led,one that uses a bulb) test light to check the power side.
Example:Window regulators,Fuel pumps,fans,door lock actuators,etc. Your problem is a good example of when it would have saved some time.I am sure it would have been dim or not lit at all. I worked briefly at a ford dealership and it was something that one of the instructors at the school advised. |
I have one of those things but I never use it much, guess maybe I need to as it would have found this problem with the first check I made. Sometimes the old tech is better for some things than all these digital gizmos we have come to love so much.
You can use a headlight bulb and connect it to a wire and then check the voltage this will tell you more than just using one of those little volt meter checkers |
Doc here,
It is good to have BOTH in your Tool box AND NEVER get "Lulled" into relying on either, until both Check out... For Instance, you have a lamp that won't light..shows 14.4 volts..(this is a good thing..) Your test bulb / lamp lights when you probe the pad on the socket and Ground the alligator clip..***?? Pull the bulb thinking the Filament is blown..no joy..Then your light probe accidentally hits the socket ground..both bulbs light dim..***??? Pull out the meter, you'll verify the drop between the 2 is 6 volts... You have a Bad Ground! Power will be present all the time..!! KEEP Both, USE BOTH.. Troubleshooting will go much faster. Doc
Cable corrosion
I have seen battery cables corrode like this. With old copper, especially under guage (smaller diameter) cables, when you add high heat from cranking, cold winters and rapid heat up, humidity, maybe a chemical reaction from things in the insulation, ...stuff happens.
Throw in dissimilar metals touching one another, and this is the exact reason I solder and not just crimp at the connections. Quality wire/insulation, larger than needed diameter, soldered joints, and cleaned and dialectric greased connections for me. Steve |
| TH400, What caused this? | Ambassador of 'Pane | Transmission - Rearend | 4 | 06-10-2007 09:41 PM |
| What caused this? | Yub350 | Electrical | 5 | 12-02-2004 07:35 PM |
| Update Pics: Bearing Failure.....what caused it | TurboS10 | Engine | 78 | 11-07-2004 02:22 PM |
| Hit 200,000 Miles and almost Caused a Serious Accident | Ghetto Jet | Hotrodders' Lounge | 3 | 07-13-2004 10:02 AM |
| cratering on my paint what caused this | pintoperformance | Body - Exterior | 8 | 11-09-2003 10:51 PM |
