Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is causing this flat spot in power?
Old 03-05-2013, 01:04 PM
ap72 ap72 is offline
Banned
Originally Posted by Landshark928 View Post
The dip around 4000+rpms is typical for a SBC with a large overlap cam. The large overlap can cause higher pressures in the intake manifold that can reduce the signal to the carburetor and cut fuel flow. Your BSFC backs up the theory. If you can adjust your carb to fatten up that area only you may get back 15-20ftlbs. With EFI it's a lot easier to get it back.
What are you cam specs?
an intake or header change can also help pick up signal in this area and reduce reversion.
