What are the cc's of stock 460 head? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 03:30 PM
I have just purchased a 1976 460 out of a thunderbird and would like to know what the cc's of the stock heads are? The rotating assembly I would like to purchase calls for 58cc 12.5 compression, 64cc 11.7 compression, and 70cc 10.8 compression ratio are these numbers correct? I thought that the stock heads heads were around 72cc or 94cc...does anyone know were this information can be found or do I need to have them tested, and is it worth the money to do so?
Old 03-04-2008, 06:59 PM
nitro_baller4692's Avatar
floppers forever
not sure of you head #'s so try this page
http://raceabilene.com/kelly/hotrod/engine3.html
Old 03-04-2008, 07:27 PM
onebadmerc's Avatar
I need a bucket of arc sparks
You most likely have D3VE heads on your 76 460 engine which would be 92-94cc chambers. Too be 100% certain look on the top of the heads right above the spark plugs by the valve covers, the head casting number will be there.
What Kind Of Cam is This? mightycarlo10 Engine 5 05-11-2008 09:40 AM
Stock 454 head swap jdg5365 Introduce Yourself 1 11-21-2007 10:32 AM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 11:08 PM
chevy head and cam suggestion needed for 327 Berliner Bel Air Engine 3 12-06-2004 10:44 AM
Longblock Chevy 350 Crate: Cam and Head concerns 360Camaro Engine 18 08-05-2003 04:51 PM
