What Clear for Calipers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2011, 02:34 PM
The clear coat on my factory painted calipers has started to peel
The paint itself is in good condition
What's the 'best' way to restore the finish?
Is there such thing as high temperature clear, and if so, is that required?
Would rattle clear be good for a small job like this, or is that always the wrong move to make?
Old 03-27-2011, 06:00 PM
302 Z28's Avatar
No rattle can paint is going to hold up on brake calipers I don't care what it claims on the can. Catalyzed urethane clear or powder coating is the only thing that will come close to holding up long term.
Vince
sanding clear then repaint with base clear agian questions tiptopss Body - Exterior 8 04-20-2010 08:09 AM
s-10 calipers goshawks00 Suspension - Brakes - Steering 4 02-18-2008 11:32 PM
Can I respray clear on top of clear that has dried if I sand it.. makaveli200369 Body - Exterior 5 07-02-2006 09:12 AM
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 08:55 AM
Dual Calipers D M N Suspension - Brakes - Steering 18 08-21-2003 07:54 AM
