What clear to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2011, 07:51 AM
What clear to use?
Going to do a 96 impala ss, best clear I've used is sherwin Williams ultra 7000. Should I use this or spi, dupont, ppg concept, etc. I like a thick clear that I can wetsand for days. Gun pref is sata jet 2000 rp for clear, and aturo wb for basecoat.
Old 11-10-2011, 08:00 AM
cyclopsblown34's Avatar
Colorsanding painter
I prefer the SPI Universal clear (It makes me appear to know what I'm doing)but use what has given you the best results.
Old 11-10-2011, 08:19 AM
Ok I'm hearing things bout that clear. But is it better than leading brands?What makes it so nice? Curing, buffing?
Old 11-10-2011, 10:16 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
As far as I'm concerned it's the best clear you can get. As good as any name brand with a better price and service after the sale.Color sands and buffs great, Has a great shine,and hard to run and take it from a pro at that.I like to put it down wet.
Old 11-10-2011, 10:29 AM
The SPI clear sprays way easier than any Dupont product I've used and unless you're looking for that trophy paint job, doesn't require color sanding. I've managed to screw it up once and that was when I used a high temp activator on a 60 degree day, it did run. The activators for SPI are spot on to the temperature they're rated for. It ain't like Chromasystem where you use a higher temp activator than what the current temperature is to get a nice peel free finish.
Old 11-10-2011, 10:49 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All of above and it is more chip resistant than some others as well..even makes me look like I know what I am doing..
Sam
Old 11-10-2011, 02:16 PM
dwhitt's Avatar
Last journal entry: camaro
I paint only 1 or 2 cars a year and have used SPI for the last few years. I agree with all the above comments. It sprays well and I always have to buff because of painting in an open bay, but if you use it I bet you will love it!
Old 11-13-2011, 06:08 AM
deadbodyman's Avatar
Wiki Edits: 11
SH 7000 is deffinetly good clear but I think Glasurat is probably the best when it comes to the buffing..SPI sprays and buffs as good as Glasurat ,as a matter of fact if you put SPI in a Glasurat can I'll bet a painter that uses Glasurat every day wont notice the difference ....so why would anyone choose SPI ??? The price ,at a 1:1 reduction it costs about 110.00 a gallon..
I've been painting cars for over 35 yrs and SPI is the only clear I've used for the last 5yrs,since I discoverd it...
Old 11-13-2011, 12:13 PM
What do you paint in? Booth, open space, diy booth? What do you start wetsanding your clear with to perfect and de-flaw?
Old 11-13-2011, 01:38 PM
swvalcon's Avatar
There's a local small shop that I tried to get them to try spi clear finally he tried it and now it's the best thing he's ever used. All it took was to get him to try it. No easy task. He's started a side line paint store with a local jobber selling it.
Old 11-13-2011, 03:23 PM
Which spi clear to use for an overall 75 degree shop.
Old 11-14-2011, 06:10 AM
Wiki Edits: 11
I've only used the universil clear and use a slower or faster hardner according to the temp.
Old 11-14-2011, 09:10 AM
If the shop is 75, use the SPI activator that covers that raing. It isn't like the others I've used where you use a higher temp activator to get it to lay out right. SPI has it spot on for excellent results.
Old 11-14-2011, 09:46 AM
Can someone post up pics of finished work using spi clear.
Old 11-14-2011, 02:52 PM
SPI clear all the way. Just sprayed the wifes mustang black with SPI universal clear. Like a mirror. Wet sanding is easy, not like the PPG clears i have used in the past, you need a damn beltsander to sand that stuff!
sanding clear then repaint with base clear agian questions tiptopss Body - Exterior 8 04-20-2010 07:09 AM
Candy...Clear or intercoat clear... mavrick77 Body - Exterior 7 03-19-2010 06:46 AM
Can you respray clear over dried clear.. makaveli200369 Body - Exterior 9 08-21-2006 07:46 PM
Can I respray clear on top of clear that has dried if I sand it.. makaveli200369 Body - Exterior 5 07-02-2006 08:12 AM
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 07:55 AM
