Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What clearance on rod to crank on rebuild?
Old 12-04-2003, 08:49 PM
shockers69 shockers69 is offline
I am going to start putting my 350 chevy together and i am reading for the second time David Vizard's "how to rebuild your small block chevy" and it does not tell to check clearances on rod to crank after both rods are on rod journal of crank.It also does not show how far down in bore compression rings should be when checking ring gap.I think in the picture it shows ring gap being checked at top of bore i guess it should be the same throughout bore if machine work was done right.
