Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What clearance on rod to crank on rebuild?
Old 12-04-2003, 08:53 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
on clearences, anything under .001 is not enough, anything over .003 is too much, just use your piston up side down without the rings on it, push the ring about a inch down in the bore.
