Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What to coat bare freshly frame??
Old 05-06-2013, 09:04 PM
sedanbob's Avatar
sedanbob sedanbob is offline
Since you mentioned having to do work on the frame before you can paint it, I think the metal prep route is the way to go. If you epoxy now, then have to weld something on the frame, you will have to grind some of the epoxy off. When you have finished all your modifications, then definitely epoxy the frame.
