What to coat bare freshly frame?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2013, 05:13 PM
Last journal entry: 41 chevy frame on the move.
I'm getting my 41 chevy frame blasted this week.What to put on frame as soon as I get it back?? I was gonna put epoxy primer on first.Gonna have to do work on frame before painting will accur.Thanxs for looking.
stefanP
Old 05-06-2013, 06:38 PM
Yep, Epoxy is a good plan.
Old 05-06-2013, 07:28 PM
Pats55's Avatar
After the frame is sandblasted wipe it down with metal prep, It will stay rust free for a year indoors.The prep will get the rust the blaster didnt get . Do your repairs then prime and paint you will get much better adheson if you top coat within the primers window. use a prep that contains zinc avaible from numerous suppliers in this hobby
Old 05-06-2013, 07:40 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Epoxy primer is my plan..use the right one and you will need to do nothing else..
Sam
Old 05-06-2013, 09:04 PM
sedanbob's Avatar
Since you mentioned having to do work on the frame before you can paint it, I think the metal prep route is the way to go. If you epoxy now, then have to weld something on the frame, you will have to grind some of the epoxy off. When you have finished all your modifications, then definitely epoxy the frame.
Old 05-06-2013, 09:48 PM
Pats55's Avatar
Two coats of epoxy primer. five coats of color. 2 coats of clear all PPG will do 500 hours of salt spray if its scratched it will rust beyond the scratch 2 coats or Mastecoat one coat of Ag111 does 14000 of salt spray and wont rust beyond the scratch
First coat of primer over a combo of bare steel and body filler Migman Body - Exterior 3 03-24-2010 07:41 AM
Wheels, can I clear coat bare metal? BIGSKY Body - Exterior 3 06-09-2008 09:04 PM
Bare steel, epoxy prime ,bondo,time frame jdss Body - Exterior 4 12-03-2007 10:47 AM
Bare metal with only a clear coat? FrankR Body - Exterior 8 04-25-2005 02:50 PM
Bare metal frame needs Painted... EASTWOOD? bg Body - Exterior 8 03-28-2005 08:27 PM
