what coating for new carbs/manifold? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 01:48 PM
Last journal entry: Better late than never
I am installing a brand new Offy tripower setup with rochester carbs etc. Everything is raw and uncoated out of the box with the sole exception of the carb bases which have already been coated with Eastwood grey.
Am I being paranoid in wanting to put some coating (maybe some type of clear?) on the units to prevent them deteriorating or should I leave them as-is?? I live in South Florida which is pretty humideven though they "shouldn't" see rain.
Thanks,
Paul
Old 03-13-2006, 02:49 PM
Technical Support Barry Grant
Paul,
You're bigger problem is going to be oxidation from the Salt air. If the carburetors are completely raw (no dye) you will have problems. As far as what to coat them with, it will depend on the "look" you want to have.
Old 03-13-2006, 03:18 PM
Thanks, they are going on an old school 29 highboy. I am guessing the 'priod' thing to do is to try to get as natural a look as possible hence my thoughts about a clear coat. Any recommendations for one?
Old 03-13-2006, 03:20 PM
If you want clear, you can have the parts clear powder coated.
Old 03-13-2006, 03:35 PM
Much appreciated, I will look up a local supplier.
Thanks again!
Paul
strange inside panel coating rlackey Body - Exterior 8 01-05-2006 06:31 PM
Powder coating Engine Chadwick Engine 4 11-26-2005 08:31 PM
Jethot Coating Manifolds RickB1B Engine 2 06-14-2005 08:21 AM
Header Clearance Issue/Question About Damaging Ceramic Coating. Ghetto Jet Engine 9 10-09-2004 12:45 PM
Bolt coating? 77cad Body - Exterior 2 03-24-2003 12:00 AM
