What combination? What power output? SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2010, 12:49 PM
I am building a motor in my 1978 Camaro. I have a 350 2 bolt main.
My current plan is,
350 .030 over
flat top with 4 relief pistons
stock crank and rods
Vortec heads with .525 lift springs roller tipped rockers, screw in studs, and guide plates
Summit/Edelbrock dual plane intake, stage 1
Camshaft, .500 lift 276,286 duration
Holley 750 carb. no choke
what kind of numbers would I be looking at with this motor?
Or could I use this kit with my other components, since the block is only a 2 bolt?
http://www.summitracing.com/parts/ESP-B13405E030/
Old 08-14-2010, 01:43 PM
bigdog7373's Avatar
Of course it's fast
I personally wouldn't waste money on steel components for a 2 bolt because if you're building an engine that needs steel components, it's most likely going to need 4 bolt mains also. Saying that, the setup you list seems good to me; i think you'll be pleased with that engine.
Old 08-14-2010, 04:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For what is needed for an accurate estimate run on software, see This thread.
Someone recently mentioned a site that could give a rough estimate- you might find it if you do a search...
The Sbc Power Question Tommy Brown Engine 11 05-13-2010 08:42 AM
Power Steering Pump SBC BBC 454headache Hotrodding Basics 3 04-26-2010 03:21 PM
Solid roller sbc Holley power valve help? hotrod937 Engine 5 05-22-2009 08:05 PM
SBC 305 hard start, backfire, no power rack Engine 14 12-28-2008 04:28 PM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
