What compression ratio is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2008, 11:21 AM
65coupe351w's Avatar
What is the comprerssion of these? will i be able to run nos? What compression would it be with 60cc chambers?
Old 12-18-2008, 12:29 PM
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 51
Judging by the photo the compression is between 7:1 and 11.5:1.
You can run nitrous depending on you heads and the piston material. Also depnds on how much nitrous you use.
Vague question gets vauge answer.
Have fun.
BiG WHiskey
Old 12-18-2008, 12:39 PM
Jmark's Avatar
More info is needed to accurately guess the compression ratio.
Piston part number to determine the CC of the dish and VR's
Head combustion chamber CC
Head gasket compressed thickness
Actual deck height of the piston as installed in your block.
Crank stroke
Block bore
Mark
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Compression Ratio? 72chevyC/10 Engine 3 09-12-2005 04:21 PM
How to figure compression ratio...... classic_chevy_guy Engine 9 07-26-2005 09:59 PM
383 Chevy Compression Ratio? Skunk Engine 5 07-06-2005 07:07 AM
327 compression ratio dadsgp Engine 4 06-23-2005 08:42 PM
