what converter to go with? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2004, 06:14 AM
heres the cam it comes with the trickflow trackheat topend package (heads ,cam, rockers ,lifters, etc)
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,700-5,700 RPM
Intake Duration 050 inch Lift 228
Exhaust Duration 050 inch Lift 234
Advertised Intake Duration 284
Advertised Exhaust Duration 290
Intake Valve Lift with Factory Rocker Arm Ratio 0.480
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.494
Lobe Separation (degrees) 110
Intake Valve Lash (in) 0.000
what stall conveter should i use?
Old 09-30-2004, 06:57 AM
brainsboy's Avatar
brains
We need to know your vehicals weight, what type of car is this?
Old 09-30-2004, 07:39 AM
Frisco's Avatar
Glad To Be Here
Selecting the correct stall speed converter is determined by cam choice, vehicle weight, rear gear ratio, rear tire diameter, intended use of the vehicle and several other factors. Hughes and/or Coan have an online form that you can fill out for them to suggest a recommended converter.
Old 09-30-2004, 06:00 PM
82 s-10 around 3300lbs , 3.73 in the rear end,daily driver
Old 09-30-2004, 07:55 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I would say somewhere in the 2500 area. But it is a little hard to tell not knowing the cubic inches of the motor.
Adam
Old 10-01-2004, 05:35 AM
its a sb 350
