Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-23-2008, 02:13 PM
lowROLLERchevy's Avatar
lowROLLERchevy lowROLLERchevy is offline
... & Insanity Ensues .....
 lowROLLERchevy's barnstar
Wiki Edits: 22
what converter to use and can flex plates be modified ?
engine:
yamahammer 3.2l v6
pt67 turbo
custom intake for top end performance
cams
forged pistons
550+ hp
might get a small shot of nitrous ... ok ... honestly will probably get a 75+ shot, because im a nutjob
trans:
th400
built for strip
automatic valve body unless we upgrade
chassis:
87 camaro w/ t tops
sub frame connectors - probably 2x4 tubes along the insides of teh rockers and tied to the rails
6 point roll bar
suspension:
12 bolt
456 gears
4 link rear suspension
hoosier drag slicks (not radials)
the engine is capable of reving to 9 grand in stock form, but its pointless because by them all power is gone
in modded form, we will probably be shifting at 9k to keep it in its power band
im about to start fabbing an adapter plate for this, and were about to buy a converter, just unsure of what to get
also have to look into how to bolt the converter up, maybe we will get lucky and it will use the stock holes ... maybe ....
but is there anything we can do to stiffen the bolt holes either way ?
and oh yea, the goal is to be able to yank the front tires on the street
Old 03-23-2008, 03:42 PM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: what converter to use and can flex plates be modified ?
You need to get the adapter fabbed up , starter placement , flexplate that will fit ...... excitera ....
then the converter guys will need to know certain depths / lengths & crank shaft pilot hole size to build a converter that will fit the custom application.
I doubt something off the shelf will fit at this point.
interesting project
Be kind to your children... some day they may be decide what nursing home to put you in
Old 03-23-2008, 04:08 PM
Wiki Edits: 22
flexplate and starter are both stock, starter is block side, so thats no prob
the yammaha bolt pattern is much smaller then the chevy pattern, so a stepped adapter flange will work well, and i have a number of places to brace it off the block
so the only matter at hand is making the adapter so that the torque converter meets the flywheel properly
and i already know that the stub on a converter will fit the pilot bushing hole on the crank
unless something weird comes up, an off the shelf converter will work ... just have to know what stall to get
Old 03-26-2008, 08:25 PM
Wiki Edits: 22
bump
anyone ?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
