-   -   what coolant to use for cast iron block w/ aluminum heads? (http://www.hotrodders.com/forum/what-coolant-use-cast-iron-block-w-aluminum-heads-205177.html)
chucksrt 09-09-2011 07:19 PM
I am almost done building my stroker Chevy 383 and I used aluminum edelbrock heads. D I need to use a certain type of coolant? What is best? Dexcool
green type
others?
Thanks,
Chuck
T-bucket23 09-09-2011 07:23 PM
green type
others?
Thanks,
Chuck
Regular Prestone or equivalent. Do not put Dexcool in it.
LATECH 09-09-2011 07:27 PM
X 2 on the ethylene Glycol base coolant. Stay away from the Dex Cool.
sbchevfreak 09-09-2011 07:42 PM
Plain old green ethylene glycol coolant, mix 50/50 or 60/40 with de-ionized water, change it every 2 years. DO NOT use DexCool, it is absolute crap and will cause more headaches than you can imageing (as it did for GM, check out this site with many complaints of dexcool failures.
chucksrt 09-09-2011 08:18 PM
Good to know! I was hoping to use a long life coolant and I thought I heard that Dexcool was junk. I worked for Both Toyota and Dodge and they have what seems to be good long life coolants. I guess I will go green unless something long life will work for sure. I will research the other car companies coolants to see if they will work. The only reason I am still wanting something else is because I was never a big fan of the green coolant. Seemed to get nasty quick.
sbchevfreak 09-09-2011 09:24 PM
People always seem to say that, but never realize that it is meant to be changed every two years. Very seldom did it actually get done, hence the "green is no good" mentality. Serviced properly, the green coolant will keep the cooling system in far better condition than the long life stuff on the market. Use de-ionized or distilled water, proper mix, and flush every two years, and there will be absolutely no problems relating to the coolant. It is when the coolant becomes acidic that you have issues. It becomes an electrolyte, and with the dissimilar metals in a cooling system, a battery is born. Electrolysis begins, and parts erosion occurs. People in general need to learn that maintenance is always less expensive than repair!!
Baka33 08-19-2012 04:03 AM
There's a product by EVANS that Jay Leno endorses.
Jay Leno's Garage: Waterless Engine Coolant - YouTube ">Jay Leno's Garage: Waterless Engine Coolant - YouTube " type="application/x-shockwave-flash" width="425" height="350">
Here's a video link. Kind of expensive. $40.00 for a two liter bottle. I believe.
Irelands child 08-19-2012 05:48 AM
I just had to change the coolant in my Ford truck and decided to use the "required" extended life spec stuff which is Xerex G-05 (http://www.valvoline.com/pdf/zerex_g05.pdf). Take a look at that as well as the rest of the Valvoline antifreeze products - they have decent write up and MSDS on all of their line. Have to say even at NAPA, the net price was not cheap - ~$20/gallon for the concentrate and I needed four (actually 3-1/2) for 50-50
66GMC 08-19-2012 06:15 AM
2 Attachment(s)
Recochem released a new "one size fits all, like pantyhose" All-Fleet ELC (Extended Life Coolant) this spring.
https://partimages.genpt.com/partimages/1372350.jpg
Can be used in everything from liquid-cooled snowmobiles to Peterbilt trucks.
Brochure attached as PDF
Yes, it's a little more expensive at a little under $20.00 / jug ... but it sure is nice not having to worry about what "color" (or "flavor") of antifreeze anymore.
It was getting ridiculous. I'm also attaching Recochem's "Coolant Selection Guide" (2-pages, with page 2 being of the most interest)
302 Z28 08-19-2012 08:34 AM
The old scuttle butt about Dexcool being junk is pure B/S. When it is used like any other coolant with distilled or de-ionized water and changed every two years there is zero problems with it. All of your long life coolants today are almost identical to DexCool.
Vince
Baka33 08-19-2012 10:11 AM
Link to Evans Endorsement by Jay Leno's Garage
YouTube - Broadcast Yourself. ____ Jay Leno's Garage and Evans Endorsement
REPLACE AND FILL ONE TIME. GUARANTEED FOR THE LIFE OF THE VEHICLE. YOU NEVER HAVE TO CHANGE THE COOLANT AGAIN.
Baka33 08-19-2012 01:05 PM
Home » Engine Cooling Systems
Here's a link to there website. Enjoy! :)
Baka33 08-19-2012 01:12 PM
$40.00 for One Gallon.
Sorry for the multiple edits. Had to make sure I got it right. Previously using mobile and it got awry. Cheers!
mmadden55 08-19-2012 01:12 PM
Green stuff or orange stuff, doesn't matter just don't ever mix them!
