what coolant to use for cast iron block w/ aluminum heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2011, 07:19 PM
I am almost done building my stroker Chevy 383 and I used aluminum edelbrock heads. D I need to use a certain type of coolant? What is best? Dexcool
green type
others?
Thanks,
Chuck
Old 09-09-2011, 07:23 PM
T-bucket23's Avatar
Wiki Edits: 26
green type
others?
Thanks,
Chuck
Regular Prestone or equivalent. Do not put Dexcool in it.
Chet
Old 09-09-2011, 07:27 PM
LATECH's Avatar
Last journal entry: New Gas Tank
X 2 on the ethylene Glycol base coolant. Stay away from the Dex Cool.
Old 09-09-2011, 07:42 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Plain old green ethylene glycol coolant, mix 50/50 or 60/40 with de-ionized water, change it every 2 years. DO NOT use DexCool, it is absolute crap and will cause more headaches than you can imageing (as it did for GM, check out this site with many complaints of dexcool failures.
Old 09-09-2011, 08:18 PM
Good to know! I was hoping to use a long life coolant and I thought I heard that Dexcool was junk. I worked for Both Toyota and Dodge and they have what seems to be good long life coolants. I guess I will go green unless something long life will work for sure. I will research the other car companies coolants to see if they will work. The only reason I am still wanting something else is because I was never a big fan of the green coolant. Seemed to get nasty quick.
Old 09-09-2011, 09:24 PM
People always seem to say that, but never realize that it is meant to be changed every two years. Very seldom did it actually get done, hence the "green is no good" mentality. Serviced properly, the green coolant will keep the cooling system in far better condition than the long life stuff on the market. Use de-ionized or distilled water, proper mix, and flush every two years, and there will be absolutely no problems relating to the coolant. It is when the coolant becomes acidic that you have issues. It becomes an electrolyte, and with the dissimilar metals in a cooling system, a battery is born. Electrolysis begins, and parts erosion occurs. People in general need to learn that maintenance is always less expensive than repair!!
Old 08-19-2012, 04:03 AM
There's a product by EVANS that Jay Leno endorses.
Jay Leno's Garage: Waterless Engine Coolant - YouTube ">Jay Leno's Garage: Waterless Engine Coolant - YouTube " type="application/x-shockwave-flash" width="425" height="350">
Here's a video link. Kind of expensive. $40.00 for a two liter bottle. I believe.
Old 08-19-2012, 05:48 AM
Irelands child's Avatar
I just had to change the coolant in my Ford truck and decided to use the "required" extended life spec stuff which is Xerex G-05 (http://www.valvoline.com/pdf/zerex_g05.pdf). Take a look at that as well as the rest of the Valvoline antifreeze products - they have decent write up and MSDS on all of their line. Have to say even at NAPA, the net price was not cheap - ~$20/gallon for the concentrate and I needed four (actually 3-1/2) for 50-50
Old 08-19-2012, 06:15 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Recochem released a new "one size fits all, like pantyhose" All-Fleet ELC (Extended Life Coolant) this spring.
Can be used in everything from liquid-cooled snowmobiles to Peterbilt trucks.
Brochure attached as PDF
Yes, it's a little more expensive at a little under $20.00 / jug ... but it sure is nice not having to worry about what "color" (or "flavor") of antifreeze anymore.
It was getting ridiculous. I'm also attaching Recochem's "Coolant Selection Guide" (2-pages, with page 2 being of the most interest)
Old 08-19-2012, 08:34 AM
302 Z28's Avatar
The old scuttle butt about Dexcool being junk is pure B/S. When it is used like any other coolant with distilled or de-ionized water and changed every two years there is zero problems with it. All of your long life coolants today are almost identical to DexCool.
Vince
Old 08-19-2012, 10:11 AM
Link to Evans Endorsement by Jay Leno's Garage
YouTube - Broadcast Yourself. ____ Jay Leno's Garage and Evans Endorsement
REPLACE AND FILL ONE TIME. GUARANTEED FOR THE LIFE OF THE VEHICLE. YOU NEVER HAVE TO CHANGE THE COOLANT AGAIN.
Old 08-19-2012, 01:05 PM
Home » Engine Cooling Systems
Here's a link to there website. Enjoy!
Old 08-19-2012, 01:12 PM
$40.00 for One Gallon.
Sorry for the multiple edits. Had to make sure I got it right. Previously using mobile and it got awry. Cheers!
Last edited by Baka33; 08-19-2012 at 01:14 PM. Reason: Had to make sure I got it right.
Green stuff or orange stuff, doesn't matter just don't ever mix them!
Aluminum or cast iron sbc heads???? BADAZZ86REGAL Engine 2 03-25-2010 10:17 PM
Aluminum Heads & Cast Iron Intake jbvcw71 Engine 3 09-16-2008 09:37 AM
Aluminum vs. Cast Iron heads 69novarodr Engine 128 04-30-2005 08:47 AM
302 heads, cast iron or aluminum? 66StangBoy Engine 4 02-23-2003 02:10 PM
Heads: Cast Iron or Aluminum? 66StangBoy Engine 2 11-18-2002 01:30 PM
