What is the correct way to sand this arch? 1941 chevy firewall.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2013, 09:04 PM
jsm1847's Avatar
Hey guys,
So I'm finally blocking my firewall after a dang year..
There is the pesky arch thingy that I want to sand in. I do have a small flexible foam pad and working it that way, but what is the best way?
I am also having issues with a small work space and a block. Do I NEED to take all residual paint off for the best possible way?
Old 08-02-2013, 11:02 PM
Not sure exactly what area that you are reffering to (arch) but what I find to work good in those tight areas is those small 3M squeeges, just wrap sticky paper around them and use as a block that way. Another thing that does work good is a bondo spreader with sticky paper wrapped around it to get into those tight corners. Hope this helps.
Old 08-02-2013, 11:20 PM
jsm1847's Avatar
Thanks for the reply. Sorry for not being clear, I'm referring to where the distributor sits.
Old 08-02-2013, 11:37 PM
Yeah I am seeing it now, what you are going to need is something that is half mooned shaped. Such as the hand held end of a 3M sanding block " ( " this type of shape. Even with something like that it can still be tough. I would try the little sqeegee first.
Old 08-02-2013, 11:53 PM
jsm1847's Avatar
Oh yeah I've got one. I didn't even think to reverse it! Thanks!
Old 08-03-2013, 06:46 AM
carolinacustoms's Avatar
Automotive Extraordinaire
A 2-3" da sander works wonders in those tight spots and saves your fingers. They range in price and quality from $25 at HF to $250 for name brands. Best money I ever spent. Just like any other DA, keep it flat and keep it moving
Kelly
Old 08-03-2013, 08:57 AM
46 chevy truck
So glad to see someone else is building one. When I brought mine home it had to of had 80 lbs of bondo or filler products covering it. Took a brazing tip and a putty knife with a big tarp and proceeded in removing all that wonderful product. Did it outside. Only bad shaped area was the front fenders or damaged area. I striped all the layers of paint on most of the sheet metal. In the engine compartment filled most of the holes with metal plugs, smoothed and sanded and sanded by hand. looks great after tons of hours but rewarding. Did you remove the inside panel to work it? cut a rubber hose for protection on fire wall to keep the sharp edges from my hands
Old 08-03-2013, 08:59 AM
Originally Posted by jsm1847 View Post
Hey guys,
It looks like there is no filler work or anything like that in the "arch" you are referring to, so "blocking" or anything of the sort is un-needed. Get that cheapie DA Kelly mentioned and strip it off to bare metal. A coat of primer and sand it by hand with a foam pad at most, that is all you need.
And for goodness sakes, remove that dip stick and the throttle cable. They only take a couple of minutes to remove and will save you a bunch of time sanding. The dipstick is simply pushed into a hole with a few rubber seals around it. The only thing that holds it in is the bolt that goes thru that bracket you see in the photo that holds the tranny on, that's all that holds it. Pull it up out of the tranny and stuff a rag into the hole while you work on the fire wall, once done you can re-insert it in the trans and run the bolt thru the bracket when the engine is re-installed. For that matter you may want to remove the whole tranny as it is MUCH easier to install the engine and trans as a unit than fight with those bolts. I don't remember how those throttle cables come off but I have to assume it has a lock nut that you simply remove and pull the cable out thru that hole.
Old 08-03-2013, 11:25 AM
I found these abrasive impregnated nylon bristle rotary brushes at ACE Hardware.
They also make cup shaped ones. There is alsoa version with six spokes, or flaps, that would work on wood, or other soft materials, but are not too effective on metal.
They chuck in a drill, and do a pretty good job of removing paint, rust, ETC, down to bare metal.
Grey is a coarse grit, blue is a fine grit, and they also make an orange, medium grit.
They work really good in drip rails, windshield openings, in gutters, and other hard to sand areas.
Old 08-03-2013, 06:22 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Kelly
Best invention since the wheel ,,also foam buffing pads 2ln and 3 in for final buff works great also
1941 chevy frame swap pat-tracy@marshallne Suspension - Brakes - Steering 18 11-24-2014 02:26 PM
1941 chevy zellaree Introduce Yourself 2 05-02-2011 04:07 PM
1941 chevy coupe suzy6574 Introduce Yourself 1 07-27-2007 02:24 PM
1941-46 chevy 1/2 ton pu rsachen Introduce Yourself 2 01-24-2006 10:45 PM
1941 Ak Chevy 1/2 Ton Spank Introduce Yourself 3 11-21-2005 10:35 PM
