what could it be? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2004, 07:37 AM
somethin4nothin's Avatar
what could it be?
Took off from a light and experienced some wheel hop. Didn't let off the gass and heard a bang. Rear wheels won't do a thing when I put the car in gear. I can come off the clutch get out of the truck and listen to something spinning in the axle shaft from the drivers side.
I had to pull it home. After a mile or so I start hearing some nasty grinding. It got worst the further we went. When I got home I could smell fluid burning. I just changed the fluid 8 mos ago. I have seen no leaks?
I've replaced everything on the truck just not the rear end.
I don't race it to much, it's really my boat puller. Any advice on a new rear end? It's a 81 chevy el camino, mod 350, 4 speed manual trans. How's the junk yard as far as complete units?
Old 01-11-2004, 07:57 AM
poncho62's Avatar
Wiki Edits: 5
Well, you are replacing the rear now. You blew the pinion gear.
Old 01-11-2004, 08:48 AM
Where should I buy one from?
I've been looking on the net just in case but haven't come across many.
Old 01-11-2004, 08:55 AM
poncho62's Avatar
Wiki Edits: 5
If its your daily driver, try your local auto recycler.
Old 01-11-2004, 08:48 PM
fire power's Avatar
sounds to me like you just broke an axel , should be an easy fix, real easy to figure out jack it up check the wheels driver side should be wobbly its your braks rubbing that gave you the smell . good luck
Old 01-12-2004, 02:14 AM
An axle?
That's what I thought at first. I'm going to pull the cover and make sure it's nothing inside. After I check that axle. I hope that's all it is!
Old 01-12-2004, 09:17 AM
Not just an axle...
Axles seem fine. Opened the cover and found the two springs and a gear broken in half from the posi. I like my posi, it's my daily driver/boat puller. Should I take a chance rebuilding or try the salvage yard?
Any numbers on a posi rear that may work with my 81 el camino?
