Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what could i have broke ( 700r4 )
Old 01-13-2012, 06:39 PM
whyholdback whyholdback is offline
Last journal entry: update
No upshift was the reason I rebuilt the first trans I ever rebuilt. It was an '84 700R-4. First check is the governor gear, but if that's good, then the next check is the valves. If none are stuck, then you're probably facing a rebuild, same as I was. I used a B&M Super TransKit, which is no longer offered, and it worked out fine.
