Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What crank keys do I use for SBC crank?
Old 02-08-2009, 07:36 PM
406 bug's Avatar
406 bug 406 bug is offline
9.82 @ 139mph
As boogie states they need to be tight. After you install them in the crank, make sure you measure the height of the key in relation to key way depth of the balancer. I found the key way on my scat crank was not machined to the proper depth so it was necessary to mill a bit off the top of the keys. This can be accomplished with the keys in place.
