what to cut unsulation with??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2008, 10:18 AM
Hi
I'm getting ready to insulate my firewall,floor,etc. I have the type of insulation with foil on both sides and jute in the middle. I've tryed cutting it with a razor knife,tin snips,regular sizzors and can't get a neet cut . Any suggestions what to cut this stuff with?
thanks
Old 05-01-2008, 10:21 AM
wretched ratchet's Avatar
one full turn after it squeeks
a better pair of scissors (aka shears) - - I've got a pair that will cut anything - - ?almost?
Old 05-01-2008, 01:02 PM
leldai73's Avatar
Its just metal,you're the boss
I second good shears.
Old 05-01-2008, 01:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You need new fresh Really sharp blades to cut with a razor knife..Which is what I use..
Sam
Old 05-01-2008, 08:51 PM
Always look up in a custom
12" Mundial table shears. Razor blade for cleanup.
Old 05-05-2008, 11:05 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You can cut it easily will a sharp utility knife, but you need to compress it so it's as thin as possible and guide your cuts with a straight edge. A good framing square for short cuts, or a heavy aluminum 5' rule for long cuts works well.
Welding on Quarter Panels mightycarlo10 Body - Exterior 9 04-02-2008 09:16 AM
cut the rear 66stangrcr Body - Exterior 1 03-13-2006 08:13 PM
Can a windshield be cut BLOWN 1100 Body - Exterior 11 02-09-2003 11:40 AM
Exhaust Cut Outs mac Engine 1 06-25-2002 08:19 PM
