What is a Dana 35 good for? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 03:46 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I have a disc brake Dana 35 sitting around with munched gears. Is it good for anything? Paperweight? base for a coffee table?
Old 01-20-2011, 04:21 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
jeep wrangler?
Old 01-20-2011, 04:34 PM
big gear head's Avatar
High Performance Rear Ends
Front or rear?
Old 01-20-2011, 05:44 PM
Last journal entry: the starting point
might work ok as an anchor for a large boat
Old 01-20-2011, 05:49 PM
LATECH's Avatar
Tote trailer axle or maybe for a windmill.
Old 01-20-2011, 06:03 PM
Originally Posted by big gear head
Front or rear?
Good question.
Old 01-20-2011, 08:07 PM
prostreet6t9's Avatar
Differential/Driveline
If its out of a Jeep it will be a rear diff. Being a disc brake setup it may be a super 35. You might get the BOM# off the housing and I can tell you exactly what it is and what it came out of. It just might be worth something to somebody.
Old 01-21-2011, 08:26 AM
If it's a Jeep rear axle, it won't be worth a ton to build it up, as anyone wanting to install it would likely upgrade to a larger axle once their old one comes out. On the other hand, it can be useful to someone salvaging a rear end. 35 axles are weak links and a lot of folks will buy them just for spares - and if I remember right, right and left are different. It's not junk so don't toss it, but it's not a heavy hitter, either.
Old 01-21-2011, 08:32 AM
& matts38chev
are the disc brakes complete? it is a rear right?
Old 01-21-2011, 10:34 AM
cal1320's Avatar
In the Jeep world is called a Turdy 5.
Whats it good for? It holds the frame off the ground until you can get a 8.8 exploder rear under it.
Old 01-27-2011, 07:41 AM
curtis73's Avatar
Wiki Edits: 16
Its from a 97 grand cherokee, rear.
Its a 3.73 open, disc brake.
I'm gonna have my scrap guy come get it today
.... unless the disc brake setup is valuable for anyone?
Old 01-27-2011, 08:30 AM
bentwings's Avatar
bentwings
Nothing
Old 01-27-2011, 09:28 AM
Disc brakes and 3.73 gears are something that many people are looking for. Too bad it's such a small rear end. Have you put it on craigslist or tried to sell it? You might be surprised at what you could get for it. Someone might pay $150 for it. That's probably more than you can get for scrap.
Nevermind, I forgot about the munched gears. Too bad about the disc brakes though.
Old 01-27-2011, 06:20 PM
I get quite a few calls from people that have managed to bend the housing and not break any internals. They're just looking for a good housing and would pay 250 or so just for the housing. It might be worth listing it as is and see what happens.
Old 01-27-2011, 07:54 PM
& matts38chev
there is are a lot of guys with jeep stuff that tear those 35's up and just put another one in
dana 60s mudmonster Suspension - Brakes - Steering 0 06-25-2010 02:32 PM
Possible dana 60-70?? Can anyone help ID eatonde Transmission - Rearend 14 12-11-2008 02:52 PM
What is the difference between a Dana 60 and a Dana 61 onebadmerc Transmission - Rearend 1 09-20-2008 07:22 PM
dana 44 hdbiker Transmission - Rearend 2 12-27-2006 03:02 PM
dana 300 inquiring_mind2 Transmission - Rearend 2 11-19-2005 05:15 PM
