what deck height is best.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2008, 09:05 PM
I am getting ready to build a 427 big block out of a 454 block and I'm wondering what would be the best deck height to use for the build. A 9.8 or a 10.2 .Getting a merlin block with splayed main caps. It's going in my 70 monte that I'm making into a custom cruiser. Toping it with a procharger as well. Any help with this would be greatly appreciated.
Old 08-17-2008, 11:17 PM
techinspector1's Avatar
Wiki Edits: 326
The tall block may present header fitment problems and interference at the brake booster.
Old 08-18-2008, 09:36 AM
well I will take that in account. Thanks for that bit of info.
Old 08-18-2008, 10:49 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Unless you are going for lots of cubes there is no reason to use the tall deck. You won't be able to find a reasonable intake for it (unless you are always over 3,000 rpm) If you are running oval port heads then they don't even make an intake to match the deck height and oval ports.
Stick with the standard 9.8 height.
Why are you spending all that money on a merlin block anyways? A 427 in a 4 bolt main properly prepped and assembled is good for 800 horse all day long.
Old 08-18-2008, 11:02 AM
SSedan64's Avatar
I have a tall deck Merlin built for blower but it isn't a 427. Slightly larger 632
Old 08-18-2008, 12:03 PM
Double_v23's Avatar
And that block is perfect for that application...
Old 08-18-2008, 07:38 PM
Last journal entry: PICTURE TEST
block
For your application a 9.8" block is what you want to use.
Keith
Old 08-19-2008, 09:24 PM
thanks for the insight. I think I'll stay with the 9.8 deck. The reason for the merlin block is for the splayed main caps for extra strength and am building it from scratch new. I look to be a little over 1000 hp on pump gas in a street/strip custom crusier. Definitly worth it in the end I think.
Old 08-20-2008, 07:31 AM
Double_v23's Avatar
Well in that case an aftermarket block is a good way to go for sure.
But if you don't mind me asking...how do you plan to get 1000 HP on pump gas?
I have seen 800 or so but I think that is about the limit.
Old 08-25-2008, 12:31 PM
I'll be using a procharger with intercooler to acheive the horses I'm looking for. Check them out at www.procharger.com awesome site
Old 08-25-2008, 01:50 PM
Double_v23's Avatar
I am sure that you can achieve the HP numbers but I think that your boost will have to be so high that you will need to run higher octane gas to prevent detonation. Big blocks start to detonate at about 9.5:1 on pump gas with the ignition in the right spot.
With a supercharger and enough boost to run those numbers you will have to build your engine at around 6.5:1 which sucks. Or maybe it doesn't suck...but it will be difficult to run 1000hp and pump gas. That is all.
Old 08-25-2008, 10:05 PM
Have you went and checked out the website? It shows and tells you how its done. Really not to difficult to do as long as your motors baseline hp is in the right spot. There's cars on pump gas pushing 1600+ hp. not the is just the s@#t right there...
Old 08-26-2008, 05:51 AM
engine
Just as a heads up... I built a procharged 427 pump gas small block chevy. It is right around 750 hp.
That car is almost useless on the street...Not sure what you going to do with another 250hp in a street car????
Keith
Old 08-26-2008, 08:41 AM
Double_v23's Avatar
Yes I did read the website, it doesn't tell you how to build the motor to maintain the right compression with 24 psi of boost to keep your motor from detonating. I am sure if you do your homework you will be fine. But it is not going to be as easy as bolting on procharger on the motor and letting her rip....and still run on pump gas.
Old 08-26-2008, 09:41 PM
very true. You're not going to just bolt on a procharger and get those numbers. The motor will have to be built for it with the right combo of parts to achieve your maximum numbers without trashing your powerplant like a grenade. My car isn't going to be a daily driver but will still be very streetable for the cruises.
Sbc Deck Height? junior stocker Engine 9 10-29-2007 12:41 PM
how do i figue out deck height denny1977 Engine 3 01-24-2006 02:57 AM
Can you use a dial indicator to measure deck height? Malibu73 Engine 9 10-26-2005 09:42 PM
What is Stock Deck Height? Chevy21 Engine 8 09-29-2004 11:00 PM
deck height? Blag General Rodding Tech 2 03-30-2003 04:37 AM
