What diameter exhaust pipe to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2007, 12:01 PM
Hello everyone. I have a question in regards to what inside diameter exhaust pipe to use. As you probably know, I just put my rebuilt 350 in a '81 El Camino. It already had dual exhaust on the motor that I took out. I have left most of that exhaust system intack. In other words, it is still attached to the car with the exception to the exhaust manifolds which are removed. I have dynomax headers which I believe are 1 5/8 diamter. I am thinking about just attaching the existing exhaust to my headers with a crossover pipe--to equalize bank pressure-- right after the headers. I think he has cherry bombs on this thing also. To my questions; what diameter exhaust pipe should I be using with the headers I have? How far back should I put the crossover pipe? Should I remove the cherry bombs?
As always, thanks for any and all responses, advice, etc.
rob
Old 09-25-2007, 01:34 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Originally Posted by F-BIRD'88
I would go with a 2.5" dual exhaust system. Put the crossover pipe just behind the transmission tail housing. i would ditch the loud, (pull me over) restrictive, power robbing red neck cherry bomb mufflers for some 3 chamber "turbo style" 2.5" in/out hi flow mufflers mounted in front of the rear axle on either side of the drive shaft.
With full tail pipes over the rear axle, exiting at the bumper.
Consider the Dyno Max Super Turbos. If catalytic converters are required use 2.5" Carsound" ( Magnaflow) small case converters installed as close to the headers as practical. Even if you have to move the crossover pipe back a little bit. These hi flow cat converters will not hurt the engines power at all and the emissions fuzz will leave you alone.
Hi newdad,
F-Bird has it right, that set-up would be perfect.
Take care,
rich
Old 09-25-2007, 02:58 PM
E.T. divided by $ spent= Speed
Redneck!!!! Theres nothin better than a set of those and a rattle can black paint job and some nascar apparel. Why I'm thinkin on gettin the brush out and puttin ole #3 on my dodge neon right now. lol
Old 09-25-2007, 03:21 PM
Thanks for getting back with the responses to my questions so quick.
Ok, that sounds good, but what is the best way to go from a 1 5/8 inch diameter header to a 2.5" exhaust system?
Old 09-25-2007, 04:00 PM
Notorious's Avatar
Hot rodder, not street rodder!
If it's stock, likely whatever system you have will be adequate since it sounds like it's already duals. The crossover is an excellent idea. I consider one of these, or it's more modern cousin the X-pipe, a necessity in any dual system. Every time I've added either to any existing dual system, the difference in torque and response was immediately evident. And of course there's solid science to back that up.
Old 09-25-2007, 04:46 PM
DeathRattle's Avatar
Some Punk Kid
I'll third the use of dynomax super turbos. Can't beat em for the price for the quality and the sound.
Old 09-25-2007, 04:48 PM
Hi newdad,
Only the primaries are 1 5/8" they
then go into a collector usually 3"
then you have a reducer that bolts to the
collectors, & are welded to the exhaust pipe.
rich
Old 09-25-2007, 06:20 PM
I dont see how that the cherrybombs are power robbing there perforated not louvered core ...the x pipe will quieten you down a bit also
Shane
Old 09-25-2007, 08:06 PM
Diameter pipe
I like the advice F-Bird'88 gave you except the catalytic converters should be as close to the engine as possible. They don't work properly unless they're hot and the further back they are the cooler they run.
Old 09-25-2007, 08:29 PM
Shane Don't mean to insult ya and I hope you take this with the jokeing friendly intent but soon as I checked your location, It became all clear to me.
The cherry bomb mufflers seem like they would be un restrictive since they are real loud and you can see right through the core. but they actually are quite restrictive compared to a three way turbo chambered style muffler. they don;t flow air near as well. The louvers hanging in the airflow path really kick up a lot of air turbelence. not your best choice.
No problem bout the location I'm a redneck but did cherrybomb go back to louvered core? there supposed to be perforated ......I'm not running them so I dont know I'm running a set of chambered mufflers that I built(flow a heckof a lot better than the "glasspacks"that I tookoff they were in reality twin tube baffled louverd core mufflers with no packing...they are now straight through with no tubes or packing just waitin on the right thing to put them on)
Shane
Old 09-25-2007, 09:12 PM
charger528's Avatar
Last journal entry: 1991 Mustang LX Mopar powered Drag car
I have a 2 1/2" system with dynomax mufflers and 4" chrome tips and stock manifolds it works very well. Its a little on the load side but i like it that way.
after i install the 528 big block which has a set hooker supercomp tuned headers 1 7/8 primaries 3" collectors which i selected this due to clearance issues if i could i would go bigger. Im considering a 3" custom system with cross over.
not sure how much i will benefit from changing over but i am trying to squeeze every once out the combination i can.
the car its going in is fairly heavy and my goal is to go as fast as i possibly can in a street car on my budget.
Old 09-25-2007, 09:23 PM
Do the conical perforations protrude to the inside of the flow pipe or to the outside? And what's the inside diameter of the flow pipe itself?
Old 09-26-2007, 09:55 AM
Heres what I'm running picture not to scale got the metal for free couple bucks worth of migwire and $4 can of ceramic paint
14 x 9 1/2 x 3 case front baffles are 2 1/2 v baffle is 4inch on each side and rear baffles are 3 1/2 IIRC
Shane
Old 09-26-2007, 09:03 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
perforated- inner tube (usually same size as exhaust tubing) has holes in it.
the louvered ones are the ones to avoid that kick up a lot of air turbulence. See pic.
Old 09-26-2007, 09:59 PM
That looks more like the throat of a sandworm than a muffler. What kind is it so I can be sure not to buy one?
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 10:51 AM
Why an H pipe ?? tinman386 Engine 26 09-04-2007 02:40 PM
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 02:30 AM
Exhaust X pipe configuration Jag Daddy Engine 6 04-02-2003 05:16 PM
