What did this come out of? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2002, 06:05 PM
Post What did this come out of?
I have an engine here that I know nothing about. I had to replace the starter and the one that finally fit was supposed to be for a Chevy 307, but that was all the info I have. Is there a site that I can punch in the EIN and get info on the make/model/year it originally came in?
thanks for any help.
Old 09-18-2002, 06:46 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Cool
there is a book of casting #'s you can get at a good parts store or you can scroll back through the posts in this forum there are a few web sites that have it and the sites are listed in a few posts good luck
Old 09-18-2002, 06:49 PM
deuceguy's Avatar
Cool
here's one site
<a href="http://www.mortec.com/castnum.htm" target="_blank">http://www.mortec.com/castnum.htm</a>
good luck, Jim
Old 09-19-2002, 06:36 AM
Post
Thanks a ton guys. I did a web search and a forum search but I guess i didn't use the right keywords. I'll run it through that site later on when i get off work :p
Old 03-08-2003, 12:25 AM
Jared's Avatar
Post
here are 2 links that might help you out. I dont know if they work for every chevy but they found mine. Not just for camaros like the title says. http://www.nastyz28.com/spmenu.html
On most engines the numbers that you need are on a pad infront of the passanger side bank of cyl. The pad projects out from the blocks deck and might be burried behind acc. or paint. if not there they can put them above the oil filter I think not real sure though. also on belhousing either side depending on what num your looking for. If nothing else you can find the year and what the heads are supposed to be on and that will rule out some possiblities. good luck .
