What did i do to my T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2014, 07:33 PM
I am running a th350 behind a small block and it sees mostly track time. I know that a glide or 400 would be stronger but its what I have and I'll have to run it for now. My selector shaft seal and pan gasket was leaking so I changed them both. I had a hard time getting the seal out because I didn't have much room to work. I ended up taking out some of the internal linkage.
Long story short, I must have got something back together wrong. It shifts fine but if you shift into neutral, I have a hard time getting it back into any gear (forward or reverse). It acts like a transmission does when its low on fluid. If you rev it up, it will lurch into gear as it idles back down. Fluid level is fine. I DID find some metal shavings in the pan so I cleaned it out and put in a new filter in hopes that it was just casting flash that may have broke off and made it into the pan. The transmission shifts nice and firm and don't seem to slip. Im hoping to get through the rest of the year with it and pull it and the motor out over the winter to freshen it up.
Have I got something back together wrong? (didn't have any extra parts!) Could I have moved the shifter cable enough when I removed it that I needs adjusted? (I just removed the whole bracket with the cable so don't think it moved any). Sorry if I didn't give enough info. Thanks in advance!
D
Old 07-21-2014, 06:44 PM
Anyone?!? Transmission guys? Hello... Is this thing on?
Old 07-22-2014, 06:16 AM
I'll take a stab at it. There's not a lot to mess up on the shift linkage on a TH 350 internally. Internally, all that happens is engagement / disengagement of the park pawl and movement of a spool valve in the valve body to direct fluid pressure for each gear selection. I would first completely disconnect shift linkage at transmission. Grab on to the linkage at the tranny and run it thru all gears starting at Park to R to N to 3 to 2 to 1. Of course, do all this without engine running. There should be definite clicks or detents into each position. If you don't, drop pan an investigate internal linkage. If that checks out, Put trans in Park and put shifter in Park. The shift linkage connection to the trans linkage should line up perfectly. If not, your linkage mount may be wrong or adjustment is wrong or something. Once you get Park all lined up, connect linkage and put shifter all the way to 1 position. Then disconnect shift linkage at tranny and make sure tranny is truly in 1 gear and linkage lines up perfectly. If that checks out, the linkage set up is good. I've seen aftermarket shifters and cables sometimes interfere with trans cross members, trans housings, exhaust parts or E-brake cables. The trans linkage has to work smoothly through out it's travel from Park to 1. Same with the throttle kick down linkage or cable. If all this checks out and you still have problems, the chips in bottom of pan indicate lot more serious internal trans problems. Good Luck.
Old 07-22-2014, 08:21 PM
Thanks for the reply. I watched the shifts while I had my wife run through the gears and everything seemed to be working right. I think Im going to try adjusting on the shift cable and see if that will work. Im hoping to get a few more races out of it then I plan on pulling the engine and trans and freshen up over the winter.
Thanks again
D
350/350 set up in a questionable car.(1956 oldsmobile) Mike Hateful Hotrodding Basics 14 01-25-2015 06:51 AM
Keep and rebuild flat tappet 350, or try and get roller cam 350? jsm1847 Engine 2 06-04-2012 10:03 AM
351 Windsor: minimum 350+/350+ with stock crank,rods and heads? BB72R-Yes Engine 5 07-20-2010 08:18 PM
Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? offroader9 Engine 1 04-07-2010 01:07 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
