With the flyback voltage possible in the system , you may have burnt the condenser for the ignition system. I am assuming you are using an OE points setup?
If you are running a electronic Ignition or box or whatever, you probably fried it . If you have no lights or starter action or anything, then you burnt a fuse or fuses , or fusible link, or melted the + feed off at the horn relay, once again I am assuming you are using the OE wiring.
Maybe you could be more specific of what equiptment your car has, and a little better description of the actual problem would help, like : cranks , no start,
or
does not crank has no lights on dash but headlights work (or not)
