  #1749 (permalink)
Old 09-29-2012, 05:29 PM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by 123pugsy View Post
Thanks John.
Attaching the line is a problem. I thought about using s/s line to help with rust bleeding out and down the rim. The only problem is that sliding the line onto the rim will scrape off the epoxy primer in spots and may still lead to bleeding rust. May have to stick to plan A and weld a s/s or steel rod on top of the rim.
Have you ever used silver solder ? It would be perfect for sweating that 1/4" line to that rib. Should be able to pick some up at the local welding supply store.
