  #1952 (permalink)
Old 11-18-2012, 05:22 AM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Ok Pugs. This certainly requires more explanation.
Must be a leak between an intake port and the water jacket at the intake gasket.
If you've ever worked on a TPI, you'll know changing an intake gasket is not as easy as popping off the carb and moving the alternator, then unbolting the intake. AAAAARRRRRRRRGGGGGGGHHHHHHHHHHHHHhhhh!!!!!!!!!!!:p ain:
I will check the oil first. If antifreeze is not getting in the oil, I will try a can of BARS LEAKS and see what happens.
Edit: Oh-oh. The pic below shows its a long way for coolant to travel. I have had this happen on a 455 OLDS and I managed to stop the leak. Maybe the port was closer to jacket on the OLDS. This is not looking good at all. I wonder if I blew a head gasket on start up?
Name:	IMG_0335 (Medium).jpg
