  #3265 (permalink)
Old 04-24-2013, 06:00 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Woke up to 25 degrees and sleet/snow so I got started late.
Grinding rust is getting old real quick. Replaced about 4 ft. of steel on the other frame rail. Sand blasted remainder. Fitted trans crossmember and drilled mount holes. Installed ladder bar crossmember, drilled/bolted mounts to frame and finish welded brackets. Painted primer up inside the middle frame rails.
