The "What Did You Work On Today" thread - Page 100 - Hot Rod Forum : Hotrodders Bulletin Board
  #1486 (permalink)
Old 07-20-2012, 07:15 AM
Unless someone shows me how to use it the stud gun is a pretty harsh way to shrink. I have a shrinking tip for mine and it really is for something that you want to simply stop it from oil caning so you can slather it with bondo.
The tip is spring loaded, a HEAVY spring. When you push it on the surface with a stud in it, this spring is mashing it against the metal as you meet the ground ring that is around the tip against the metal and then you pull the trigger to make your direct short welding the stud to the surface. So when you use the shrinking tip you are MASHING this tip into the surface, so think about this now, you have a small tip MASHED into the metal right where you are going to heat it up......you see where this is going? The tip goes INTO the softened metal and you end up with a dent.
It works like a charm IF you need some quick shrinking but it is no "tin smith" tool. Again, I sure as heck am wide open for someone to show me I am wrong so I can learn another trick. I know when I was working for a guy and pulled out my stud gun he showed me how to use it as I had been using it all wrong for a few years.
Here is a video of yours truly using the shrinker it's a horrible video with me dropping the shrinking tip but it will get my point across.
How too Basics :: Stud puller shrinker video by BasicsofBasics - Photobucket
Here is one using the stud welder properly. All you need is a tap on the button to weld it, just a tap like you do on your computer keyboard. You don't burn the thing in like I did before I was taught how to properly do it. In the video you will see how I weld a couple on and give it a simple wiggle and it falls right off. Then you will see me pulling with the slide hammer on one and I can give it a heck of a whack pulling on the metal pretty good, then a little wiggle and it falls right off. You do NOT need to burn it in so you have to cut it off with a pair of wire cutters for goodness sakes. But that is how I was using it not knowing any better until my boss showed me.
How too Basics :: Stud puller video by BasicsofBasics - Photobucket
I have been looking at your videos Brian. Would it be possible that you could shrink with 3 or 4 or more short quick spurts to shrink an area instead of getting the metal so soft that in indents the area? I am not trying to be a know-it-all here. I have never had a stud gun in my hand so I have questions not answers.
  #1487 (permalink)
Old 07-20-2012, 08:54 AM
It's possible, but you don't have much heat at all unless you hold for a while. It's like the stud, if you don't hold the button long it's barely holding on and is sure hasn't created much heat.
And other thing, I need to remember is the fact that the metal on our old cars is so much different, I don't know how the gun will react on the older stuff, it is thicker but it is softer metal with less carbon so I don't know. I will try to give it a try on some older stuff. I think I have something out there that I don't care about to give it a test.
  #1488 (permalink)
Old 07-20-2012, 08:56 AM
By the way John, you are very right of course, if I move it around in a small area that should work. I'll give it a go tonight or over the weekend.
  #1489 (permalink)
1971BB427's Avatar
Swapped out my plug wires yesterday. The new MSD was shorting through the old wires where they went between heads and firewall. Went with larger/better insulation and cured the little low rpm miss I had.
Also picked up my stash of oil for the next few changes! Found an ad on the local Craigslist for an old 24 can case of Valvoline Racing oil 20/50 for $4 a can!!! Can't believe somebody still had a case of good old zinc based oil still in cardboard cans! Saves me about $2.40 a qt. over the Brad Penn I've been buying.
Now I just need to find that old can opener!
  #1490 (permalink)
Old 07-20-2012, 08:58 AM
What a find! That's like gold now, how cool is that.
  #1491 (permalink)
Old 07-20-2012, 09:39 AM
I'll give you 5 . Don't Sensor me, just joking.
Back to the stud gun. The reason I never bought one Brian was I am old enough that I hammer welded with acetylene for years. When the stud guns started appearing I learned to take 3/32 acetylene copper coated rods and stick them on with my MIG welder. Instead of using a slide hammer I lay a 6 inch long piece of 1x2 beside the "stud", grab the stud with a pair of diagonal pliers and using the wood as a fulcrum lift the stud up pulling the dent. It is a little more time consuming but really works well. Remember, I do very little customer work so time is not an issue in most cases.
I have the English Wheel and planishing hammer so I can usually get a panel stretched but if I over stretch it I end up in Pugsy's situation. Trying to find the best way to shrink a fairly broad low crown area. I built an entire 34 Ford Victoria trunk skin a few years ago and got the lower area that rolls out over stretched causing it to stick out from the body a bit. I had no way to shrink it back. I had 2 things going for me. First I was doing it for free so my Buddy was tickled with what we had done and secondly he is an artist with a TIG. He slit the lower portion in several places and welded it back. The shrinkage from the welding pulled the panel in enough to make it fit Really well. I get jealous when I see these videos of power hammers with shrinking anvils that can draw metal in as effectively as I can stretch it.
  #1492 (permalink)
Old 07-20-2012, 11:58 AM
Funny you should mention the MIG welder and studs, I thought I was a smarty pants and figured I would make a tip for the mig that would hold the stud. So I designed this tip and had a machine shop make a few for me. I was so brilliant I figured I could sell them. One problem, the mig doesn't produce enough amperage to stick it on. The amperage it takes to melt a tiny wire is a little different than welding that stud on.
So I broke down and bought the stud welder.
  #1493 (permalink)
Old 07-20-2012, 01:13 PM
Coated up 4 test pistons, with a special Abradable Powder coating so a new piston skirt profile can be developed.
  #1494 (permalink)
Old 07-20-2012, 04:04 PM
Can you explain a little bit more JD.
  #1495 (permalink)
Old 07-20-2012, 04:06 PM
Neat idea though. At least you tried.
  #1496 (permalink)
Old 07-20-2012, 04:35 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Been out in the garage making more black spots all over.
Its shrinking real quick with the torch.
  #1497 (permalink)
Old 07-20-2012, 07:36 PM
deadbodyman's Avatar
Wiki Edits: 11
Sheetrocking for me...PITA
BUT I did get a 73 alfa romano in the shop today...
The guy is a member of HR and wanted a place to do a resto on it with a little guidance from the DBM....This should be an interesting project, I have high hopes for this guy,he wants to do all the work himself ...on a tight budget ,hes a grad student...I'm all in on this one...very cool looking car I was expecting some kind of spider deal,not even close...even the motor looks cool...
  #1498 (permalink)
Old 07-20-2012, 08:49 PM
Cheer up Mike. Sheetrock mud sands a lot easier than body filler
  #1499 (permalink)
Old 07-20-2012, 11:38 PM
I am so damn tired coming home from work lately it's ticking me off. I don't have energy to go out and do anything. We are short handed and busier! I try not to do everything I use to because I just can't but I am still whooped when I leave.
Tonight I had to wake up from sleeping on the couch after the game to go out and spend my five minutes. Ended up with about 10 minutes. It's better than nothing but I am getting ticked about this. Anyway I pulled down the sides to the irons at the quarter window and put a screw thru just so the top is being stretched a little so it will be happy when I pull it back where it needs to be later.
  #1500 (permalink)
Old 07-21-2012, 12:14 AM
[QUOTE=MARTINSR;1575628]
Trust me, in about 13 years you will just be glad to tell people about the things you used to do. Of course, you will occasionally at least think about doing something. You might even think about the things you would like to do.... Ya know, Maybe I will do something tomorrow. Maybe.
build thread, projects
Currently Active Users Viewing This Thread: 27 (0 members and 27 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
