The "What Did You Work On Today" thread - Page 103 - Hot Rod Forum : Hotrodders Bulletin Board
  #1531 (permalink)
Old 07-31-2012, 09:36 AM
I didn't hit a lick at a snake.... Did go to the local cruise in last night.
  #1532 (permalink)
Old 07-31-2012, 05:08 PM
1971BB427's Avatar
Got out this morning to see if I could get rid of a small vibration the car has around 70mph. Amazing what a few degrees pinion angle adjustment can do. I dropped the ladder bar heims and adjusted the pinion angle up about 3 degrees and went for a test drive.
All the vibration went away, so she's much smoother now!
  #1533 (permalink)
Old 07-31-2012, 06:00 PM
That is great. Those little vibrations can really ruin a good trip.
  #1534 (permalink)
Old 07-31-2012, 06:22 PM
1971BB427's Avatar
I rarely get up around 70 mph, but took a couple recent trips that resulted in higher cruising speeds. I've never had much problem with those phantom vibrations, but had heard that pinion to driveline angle can cause it, so figured it was an easy thing to try. Glad I decided to go adjustable ladder bars and coilovers!
  #1535 (permalink)
Old 08-02-2012, 07:53 PM
1971BB427's Avatar
Just out cruisin around today and ran across this restored gas station in a small town close by:
That's a nice restored old '49 Chevy PU in the background! Guy uses the station as his business, but nothing to do with cars or gas. Sells motorcycle accessories. Has an old soda fountain inside restored, but not working.
  #1536 (permalink)
Old 08-02-2012, 08:28 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
well how about yesterday?????
  #1537 (permalink)
Old 08-02-2012, 09:24 PM
Started cutting metal in order to build portable hydraulic press. It has to attach horizontally to a backhoe boom. I'm going to try to press the lower pivot pin out of the bottom of the lower boom. Apparently the previous owner of the hoe wasn't quite sure what to do with Zerk fittings. This ought to be fun. I have to assemble it around the boom sideways.
  #1538 (permalink)
Old 08-02-2012, 11:50 PM
Semper Gumby
Wiki Edits: 2
Worked on restoring/custom building a compressor. I have a 2-stage Gardner-Denver compressor pump, a 5 hp Baldor industrial motor and I just scored a new C-h 60 gal tank. Problem is the tank is only certified to 150 psi and the compressor is happiest running around 180-190 PSI (where it can give 17 cfm) , but will have to live with a 140 psi cut-off. Had to make a new mount as the compressor is about twice as wide as the mount on the tank.
Rounding up all the lil doo-dads and thing-a-ma doofuses takes time, but will give me a "live forever" machine with lots of volume etc.
  #1539 (permalink)
Old 08-04-2012, 07:59 PM
bigdog7373's Avatar
Of course it's fast
Did some sanding on the firebird. Found out it's a sky bird, which i thought was kinda cool.
Also found out some rust spots o thought were real bad ended up being ver minor. But on the other hand i found rust in places i really hoped there wasn't.
I found out that when the seller said "repaired all rust", it actually means "half the car is full of bondo". Need a front and rear left quarter. Right seemed ok, i'll find out for sure tomorrow. Worst comes to worse i'll need a few small patches but not nearly as bad as the left.
  #1540 (permalink)
Old 08-04-2012, 09:01 PM
Worked on a "Basics of Basics" on removing weld on panels. And a bunch of yard work. My gas weed whacker bit the dust and I went and bought an electric one, I am damn happy with it.
  #1541 (permalink)
Old 08-05-2012, 11:56 AM
dinger's Avatar
I have the Bush Hog electric, 2 batteries, works great.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
The Following User Says Thank You to dinger For This Useful Post:
MARTINSR (08-05-2012)
  #1542 (permalink)
Old 08-06-2012, 11:20 AM
nissan's Avatar
Last journal entry: 1930 chevy ratrod pick-up
I-h
1947 I-H on a S-10 chassis lowered 2" shortened 18" with a 350 chevy motor and a toploader 4-speed. rear fenders are 37 ford fiberglass shortened.it was a freebee.
ID:	67214   Click image for larger version
  #1543 (permalink)
Old 08-06-2012, 02:35 PM
b r i a n m a r t i n ..... T h i s i s y o u r c o n c i e n c e s p e a k i n g......Y o u k n o w w h a t y o u a r e s u p p o s e d t o b e w o r k i n g o n.................
The Following User Says Thank You to John long For This Useful Post:
MARTINSR (08-07-2012)
  #1544 (permalink)
Old 08-07-2012, 06:46 AM
deadbodyman's Avatar
Wiki Edits: 11
bigdog,Please excuse my ignorance but whats a skybird,never heard of one.
  #1545 (permalink)
Old 08-07-2012, 06:50 AM
Wiki Edits: 11
I used to like messing around with Hoe's too
build thread, projects
« Trivia thread | - »
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Rip VW
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
