The "What Did You Work On Today" thread - Page 11 - Hot Rod Forum : Hotrodders Bulletin Board
  #151 (permalink)
Old 01-23-2012, 12:37 PM
life is a temporary assignment
He should lower it a bit.
Well... I can only lower the top more now.... It will seat on the ground right now... With the air out the bag's..
  #152 (permalink)
Old 01-23-2012, 01:59 PM
Man !!!! I must be breathing to much grinding dust..... I put seat where I should have put SIT....
  #153 (permalink)
Old 01-23-2012, 06:04 PM
deadbodyman's Avatar
Wiki Edits: 11
Dont forget to bring your tools Mat...
Randy that last pic was takin at a great angle ,how close to the floor were you?????
  #154 (permalink)
Old 01-23-2012, 07:36 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
he was standing on his head with the camera upside down
  #155 (permalink)
Old 01-23-2012, 07:47 PM
& matts38chev
today more rust repair
finished cutting off the bottom of my RH rear quarter
I have the rocker roughed in, so now I have a reference point for the quarters' repair panel
I cut a little at a time, on both the rusty stuff that is coming off, and fitting the new piece
while the area was open, I cleaned it up and added a doubler to the back side of the door jam,
(because I am going to move the body mount to that spot)
still have more to go, try again tomorrow
Name:	first cuts RR Q.jpg
ID:	62153   Click image for larger version
Name:	RR doubler.jpg
ID:	62154   Click image for larger version
ID:	62155   Click image for larger version
  #156 (permalink)
Old 01-23-2012, 09:54 PM
Very cool Matt, you are getting-r-dun.
I came home very tired tonight but still got out there and put the door glass in my drivers door. Amazing how much easier it was after reading the GM Manual!
  #157 (permalink)
Old 01-23-2012, 10:13 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I did a little more on the Bonneville,, the tail light lenses were pretty shabby, and there are no replacements available, so I made my own
some red plastic from Tap plastics, and a piece of parabolic prisum plastic ( its the plastic covers that are in most floresent light fixtures,,it has the fishured prisums on one side to reflect the light, and a smooth side , you glue the smooth side to the back side of the red lense..
if I would have cut old the red lense off the body of the light, I wouldn't have had anything to glue the new lense to ,, so I just glued the new lense to the old one,, after cleaning it up as good as I could,,
now before I install them I will give them a little shot of the dark lense spray, to kinda match the new windows,,,
also found a new windshield, locally, and much cheaper than from OPGI 185$ delivered,, OPGI was 285 + freight from calif,, got that done also,,
its getting there slowly
ID:	62166   Click image for larger version
ID:	62167   Click image for larger version
ID:	62168   Click image for larger version
ID:	62169   Click image for larger version
  #158 (permalink)
Old 01-23-2012, 10:29 PM
That's pretty slick work there Bad Rat.
  #159 (permalink)
Old 01-24-2012, 10:17 AM
Bad Rat's Avatar
Wiki Edits: 2
Thanks Brian,, sometimes ya gotta do what ya gotta do to make it work,,,
I,ve made a lot of tail lights tho, mostly the flush type,, lots more work,,
ID:	62184   Click image for larger version
Name:	bike build 017-1.jpg
ID:	62185   Click image for larger version
Name:	bike build 056.JPG
  #160 (permalink)
Old 01-24-2012, 11:30 AM
Don't forget to bring your tools Mat...
Randy that last pic was taking at a great angle ,how close to the floor were you?????
I was about 15'' off the ground on that shot.. I wasn't on my head.. But I was on my knee's..
  #161 (permalink)
Old 01-24-2012, 03:21 PM
Wiki Edits: 11
I spent the weekend in the Riviera ,it was extermly hot ...
Today I'm working on getting it running so the windows go down and putting tires on it...
The old lady did say if I brought any more cars home I be living in it ...
I didnt think she was serious......
  #162 (permalink)
Old 01-24-2012, 08:51 PM
Last journal entry: Finally some floor!
Got home from work & I had promised myself I would put up three more blinds in the family room. (Keep the peace kinda thing! If my better half ain't happy, I ain't gonna be happy). Brought some cardboard home to make templates for the floor on the 33 Ply. Not enough time to start on anything else after that so I just posted some pics into my journal of the project I put on hold for this winter so I can do some of the mods on the Ply.
ID:	62194   Click image for larger version
ID:	62195   Click image for larger version
  #163 (permalink)
Old 01-25-2012, 05:42 PM
CometCyclone's Avatar
A Comet with a T-Bolt scoop....... What engine are you putting in it? It'll have to be a 289-302 era small block, maybe a 351W, but if you want anything bigger, you will have to relocate/modify the shock towers.
Is it a Caliente or a Cyclone?
  #164 (permalink)
Old 01-25-2012, 06:41 PM
& matts38chev
I got my RH quarter repair panel modified and put on
I ended up splitting the back side at the fender bead, because of the cuts/fitting already made at door jam
it worked out OK because the bead/roll bodyline at the fender was bigger/rounder then the repair panel, so I was able to fix that at the same time
I cheated and made a doubler for the back side (kinda like putting a flange on it)
ID:	62227   Click image for larger version
ID:	62228   Click image for larger version
  #165 (permalink)
Old 01-25-2012, 07:15 PM
Hello CometCyclone: It's an original 4sp Cyclone I found in Tennessee about 11 years ago, body only but in pretty decent shape. It took me 9+ years before I started to work on it. I posted a little more about it in my journal. I have always liked the style & there are not too many around, so it appeals to me for something out of the ordinary.
build thread, projects
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Fasto44
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
