No car work today, just play! Went to the swap meet and found some deals. Picked up a nice heavy cast aluminum finned trans pan for the gasser, then got to the next building and found a full set of tires and wheels for the '69 Suburban too! Great day!
Must be a leak between an intake port and the water jacket at the intake gasket.
If you've ever worked on a TPI, you'll know changing an intake gasket is not as easy as popping off the carb and moving the alternator, then unbolting the intake. AAAAARRRRRRRRGGGGGGGHHHHHHHHHHHHHhhhh!!!!!!!!!!!:p ain: I will check the oil first. If antifreeze is not getting in the oil, I will try a can of BARS LEAKS and see what happens. Edit: Oh-oh. The pic below shows its a long way for coolant to travel. I have had this happen on a 455 OLDS and I managed to stop the leak. Maybe the port was closer to jacket on the OLDS. This is not looking good at all. I wonder if I blew a head gasket on start up? Last edited by 123pugsy; 11-18-2012 at 05:28 AM. |
No more steam!!!!!!
Installed a bottle of BLOCK SEAL and ran it for about 1/2 hour and no more steam. Sweet. Pics below while engine was running. |
| The Following User Says Thank You to MARTINSR For This Useful Post: | ||
123pugsy (11-18-2012) | ||
I had a few hours this morning to work on my 56 so I cut off the old leaf spring saddles from my rear axle so I could weld on the new ones. Then I boxed in the back part of the frame and did a C notch for some added axle clearance. After mounting the axle to the mono leafs, it looked like it could some some extra room.
Went for a test drive and all went well.
Truck idles very smoothly in drive and roasts the tires from a stop. The vacuum for the brakes is also better but still have some issues there. |
I added a vacuum reservoir on my T-bucket. It seems to help.
I need to do something for the brakes in my Gran Sport, I am thinking that damn cam just doesn't provide enough vacuum. It's my next project. Today I had a Pugsy day, I SOLVED my problem with my washer draining! WHOO HOO. I went and rented the big boy and went up on the roof and put 70 feet of snake into that bad boy. Ran a load of wash on high water level and it drained perfectly! WHOOO HOOOO the hell of the drain is over! Brian |
Shades of MartinSr's washing machine wars. I spent half the day (the part where I was NOT watching the final NASCAR race of the year) cleaning the fins and etc under the fridge.
Yowzaa! It is astonishing how much *&%$#*! there was under there and how much quieter the fridge runs now! Likely gonna save me a bunch in power costs, too, 'cause it'll be so much more efficient! Took 2 hours with compressed air, vacuum cleaner, back to air blow, vacuum up more junk, repeat. Gotta make a note to do it once a year instead of about 5-6 years since I did it last! |
Brian |
![]() Brian |
The vacuum is no longer an issue. I was able to push the brake pedal down easily for a change and still not stop good.
I think I'll need to adjust the rears and do a bleed job. |
| Tags |
| build thread, projects |
| Recent Hotrodders' Lounge posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Another engine "tick" diagnosis thread....(long) | ForceFed86 | Engine | 2 | 04-09-2011 03:54 PM |
| Hahaha Remember that "Hemi in a Camaro" thread... | Crazy Mopar Guy | Hotrodding Basics | 6 | 10-18-2008 06:34 PM |
| Increase thread title "preview" time | cboy | Hotrodders Site Suggestions and Help | 16 | 07-03-2008 08:45 PM |
| MuscleCarKid_1991 "Senior Project" thread: Dumped | Jon | Engine | 2 | 03-22-2008 08:01 PM |
| "Trial fitting parts" thread vs. paint thickness | rcurrier44 | Body - Exterior | 3 | 01-26-2005 05:24 PM |
