The "What Did You Work On Today" thread - Page 147 - Hot Rod Forum : Hotrodders Bulletin Board
  #2191 (permalink)
Old 01-08-2013, 11:45 AM
I made one frame to fender bracket. One more like this and four more of a little different design.
  #2192 (permalink)
Old 01-08-2013, 01:18 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Just wanna throw this out there....... Spray in expanding foam insulation is not a good way of fixing rust. I have seen some weird things people have done over the years but this one beat them all. Someone used expanding foam spray to fill in the missing rusted section on a body mounting brace and then used bindi and undercoating to hide their "repair". Can't believe anyone would do something like this.
  #2193 (permalink)
Old 01-12-2013, 06:48 PM
Finally put some Epoxy on the roadster. At the rate I am going I will get this car repaired by mid May.
  #2194 (permalink)
Old 01-12-2013, 07:10 PM
Beautiful work.
  #2195 (permalink)
Old 01-12-2013, 07:11 PM
Five minutes a day! I got out and did some cleaning from all of my Christmas projects that have kept me from my car. I see a big empty space in the garage to put my trucks cab! WHOO HOOOO!
  #2196 (permalink)
Old 01-12-2013, 07:48 PM
That will be cool. After all these years I know it will be great to see her come back to life. It is so much more fun to build than repair. Get to it.
  #2197 (permalink)
Old 01-12-2013, 08:25 PM
Yeah, I have a lot of memories with that truck.
  #2198 (permalink)
Old 01-14-2013, 09:15 PM
32chevy vett's Avatar
32chevy vett
I'am building a six post delivery express wagon body.For a Model T Ford. Bent the steel around the tailgate And worked on the windshield posts.
  #2199 (permalink)
Old 01-14-2013, 09:19 PM
Well I got a little merging of threads. Over at on the Trivia thread I posted a photo of this vacuum canister from the power brakes on my bosses 56 Plymouth. I asked him if I could have it for my Gran Sport and he said sure. You see my motor has a pretty radical cam and all I have is 10 inches of vacuum at idle, needing about 18 the power disc brakes can be an issue. I have never been happy with how this car stopped, needing lots of pedal pressure. Well at 1200 rpm I have about 23 inches so I figured if I had a canister to save that vacuum so when I stopped I could use it, hmmmmm. So I brought home the canister and I'll see if it will help.
It fits right in there behind the right headlamp.
  #2200 (permalink)
Old 01-14-2013, 10:52 PM
496CHEVY3100's Avatar
Big boys wear Bowties
Last journal entry: ,
Martin people around here are using electric vacumn pumps from a caviler ,seems to work good .I have Not tried this ,but lots of guys use them at the strip ,Paradise Drag Strip ,little plug .might work on your car. havent seen washer fluid holder like that in a while do you have the 3 corner bottle
  #2201 (permalink)
Old 01-14-2013, 10:53 PM
Sounds like an option, thanks. Do you know the year Caviler?
  #2202 (permalink)
Old 01-14-2013, 10:55 PM
PHOTOS! Sounds like a fun project.
  #2203 (permalink)
Old 01-14-2013, 11:04 PM
No, but i will find out and post it for you.
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
MARTINSR (01-15-2013)
  #2204 (permalink)
Old 01-14-2013, 11:08 PM
Last journal entry: The donor truck
I'd be interested as well for my old Rat (rust)chaser GMC High Sierra It's been cammed and has lousy vacuum.
  #2205 (permalink)
Old 01-15-2013, 08:00 AM
Brian .The 1982 -2000 Chevy Cavalier has the electric vacumn pump , i ask on of the local racers ,he said to get the Pump, Delay valve,Regulator ,Vapor filter, Vacumn Reservoir,from the donar car ,also there is an ,aftermarket adjustable regulator avalible,hope this help you . also there are 2 different engines in these 1 is ohc the other is ohv one does not produce enough vacum dont know which,i have one of each if rain stops today i will go down and see which or both have these.
build thread, projects
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
