The "What Did You Work On Today" thread - Page 166 - Hot Rod Forum : Hotrodders Bulletin Board
  #2476 (permalink)
Old 02-21-2013, 08:57 PM
Originally Posted by 1971BB427 View Post
Went out and picked up a 9 inch Ford rearend for my '63 Falcon gasser project today for $100! No third member, but the width is right, and everything else is there. Glad I wont have to have one narrowed to fit the old Falcon!
I would bet if it fits that Falcon it is either a '57 Ford or a Bronco. I know a guy who would let you make a profit up in Chattanooga
I have my doors ready to shoot with some SPI epoxy tomorrow.
  #2477 (permalink)
Old 02-21-2013, 09:08 PM
This is how much I mean you MUST work on your car for 5 minutes minimum. I haven't been doing it but when I get it in my head darn it, I am GOING to do it, So tonight I get home from work to find out there is a power outage. I went out to the garage with my "miners hat" on pulled the water pump from the Gran Sport.
Now that is the spirit we are looking for.
  #2478 (permalink)
Old 02-21-2013, 09:10 PM
1971BB427's Avatar
What the heck did that 9" come out of that would be narrow enough for the Falcon? The only thing I can think of would be a Mustang or a Bronco I am thinking. If it's a Mustang rear, it may be worth a mint!
Supposed to be out of an early Bronco, which makes it .75" wider than a early Mustang 9 inch. Going to go look at a 3.50 posi third member tomorrow, so hopefully it wont eat up too much of the build budget for the rearend!
  #2479 (permalink)
Old 02-21-2013, 09:15 PM
Looking good John!
  #2480 (permalink)
Old 02-21-2013, 09:18 PM
That ought to be an excellent unit for you. My roadster has a 57 Ford that a buddy of mine had in Vancouver, Wa just across the river from you. He gave me the rear end and put it on a pallet for me. I was able to get it shipped for 140 dollars so it ended up a bargain. I have a 3.25 gear in it but wish I had a 3.50 with the T5 overdrive
  #2481 (permalink)
Old 02-21-2013, 09:50 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by Dave57210 View Post
Today I embarked a whole new adventure - I have never been inside a disease-el engine before and now I seem to have somehow wound up with a teeny little Isuzu 3 cyl in my shop.
Right now I am guessing at what it needs, but:
It is putting out somewhere between a half and third of its rated power AND it is spitting drops of oil out the exhaust. It is on a 10 kw generator and I can stall the engine with a load between 3 and 4 kw on it, so it needs help.
From exhaust manifold temps I know it has one dead hole.
First thing to do: Get a compression tester that goes WAY up there in numbers - the stock comp rating on this engine is well over 450 PSI, so my Mac Tools tester just ain't gonna do it.
"Horrible Fright" has one that reads up to 1,000 psi for under $30.00 so - for a single use..... (esp since I'm not looking for precise numbers - just comparo numbers.)
Rings? Valves? All of the above?
Stay tuned.....
The most common cause of a dead cylinder on a diesel engine is a bad fuel injector. Those drops of oil could be fuel that is squirted into the cylinder instead of atomized. I am only speaking form 37 years of experience working on diesel engines, so I might be wrong, but that's what I'd check first. Allan
  #2482 (permalink)
Old 02-21-2013, 10:50 PM
I would tend to listen to 37 years of experience. I am not a tech but after 10 years of customer support with Freightliner usually raw fuel is the result of an injector failure. Good luck
The Following User Says Thank You to John long For This Useful Post:
adantessr (02-22-2013)
  #2483 (permalink)
Old 02-21-2013, 11:02 PM
1971BB427's Avatar
I'm going to go look at a 3.50 posi third member for the 9" Ford tomorrow. Probably will cost me more than double what I paid for the rest of the 9 inch, but it's exactly what I was looking for to go behind the 454 Chevy in the Falcon.
  #2484 (permalink)
Old 02-22-2013, 04:45 PM
Put 3 coats of Epoxy on my doors today. There is quite a bit of work to do along the belt line but other than that, they should be pretty easy to get ready for paint.
  #2485 (permalink)
Old 02-22-2013, 05:16 PM
1971BB427's Avatar
Looking really good John!
  #2486 (permalink)
Old 02-22-2013, 05:33 PM
Thank you sir. Did you get your Posi?
  #2487 (permalink)
Old 02-22-2013, 07:24 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
How do all of you keep your shop so clean.they make mine look awful .i need to get rid of a lot of parts but i would need them next week if i did... your paint is lookin good
  #2488 (permalink)
Old 02-22-2013, 08:16 PM
You make a good point. At this point when I want to buy something I have to consider if I am going to use it often enough to warrant storing it. Space is as valuable as the stuff.
When I moved back east the guy who owned the moving van told me the first thing he learned was all his crap was stuff and other peoples stuff was crap..... I think he made a good point. I really like my crap, er I mean stuff.
  #2489 (permalink)
Old 02-22-2013, 08:35 PM
mud.man.rj's Avatar
today and yesterday.
Ported a set of Big Block Dart Iron Eagle cyl. heads, also port matched them, just need some time to install on the 454. Then custom pushrods next.
  #2490 (permalink)
Old 02-22-2013, 08:36 PM
mud.man.rj's Avatar
heads again,
Forgot the picture, haha.
build thread, projects
Currently Active Users Viewing This Thread: 14 (2 members and 12 guests)
tech69, 123pugsy
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
