The "What Did You Work On Today" thread - Page 18 - Hot Rod Forum : Hotrodders Bulletin Board
  #256 (permalink)
Old 02-04-2012, 09:15 AM
Nicely laid out, I had a polly cell it deformed, top started to collapse after a year or so. Installed aluminum just a heads up to the future. You probably know this but there is an AN bulkhead fitting with a 45 you could use on the right had fuel line.
  #257 (permalink)
Old 02-04-2012, 09:24 AM
Prof. T. Soggmeyer's Avatar
Plan B
WTH? You are absolutely right! HOLY CRAP, here I have a friggin mouse pad right under my hand and didn't notice that! LOLOLOL, and I have a couple of new ones at work, thanks!
You are most welcome Brian.
  #258 (permalink)
Old 02-04-2012, 09:29 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by Prof. T. Soggmeyer
I was thinking that a mouse pad would work for your gaskets. cheap,strong,and available.
brad...
Now theres an idea...
  #259 (permalink)
Old 02-04-2012, 09:51 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by StreetKruzer
Tonight I used the patterns for the floor halves and cut some sheet metal. I still don't quite understand everything about using the metal brake, but they turned out great!. A little bit more trimming and they are ready. Went ahead & cut a piece and rolled it for the back part of the tunnel. I saved the "easy" pieces for tomorrow. I hope to have most of the floor pieces ready this weekend. I think I need to complete most everything else; brake & fuel lines, wiring, etc. before I put them in permanently. Going to try to get the seat rails figured out also. Any advise on how to do the front of the trans tunnel? Cone shapes are not me favorites. Bob
Laid out cone shapes in graphics class in high school about 43 years ago. Good luck.
Name:	trans tunnel.jpg
  #260 (permalink)
Old 02-04-2012, 10:09 AM
Oh Heck yes Ed, that sucker looks BEEEE-UUUUU-TEEEE-FOOOL! It looks too darn good to cover up under a carpet or trim cover! Very nice!
  #261 (permalink)
Old 02-04-2012, 10:52 AM
Last journal entry: door trim
winter
washed my truck!
  #262 (permalink)
Old 02-04-2012, 11:19 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
Originally Posted by stich626
today, I plan on building my eliptical machine, (fitness) then go into the mad scientist lab ,and try again to make the wood inserts for the gauge panel.. first time was a major fail.. me thinking I could make round cuts with a saber saw.. they where round, but not good enough.. bought some hole saws.. so we'll be cooking with gas now.. just nowhave to figure out how to angle the outside cut.. as the gauge panel is 1" thick and the holes are smaller on the inner side than the face, by 3/8th" so, I'll mount the inserts on a bolt and spin it on the drill press(poormans lathe) and with a sanding block. hand fit them.. then cut the inner hole and router the edge..
then fire up the replacement computer, as this one is 4 weeks old have locks up..(dells testing showed harddrive on way out) the send a computer but it was the wrong one.. so.. fingers crossed this one will be correct..
then load everything onto the new one.. and then I can built a build thread/journal ..
then get ready to .wire the gauges, and be clean and ready to watch, our pats, kill the N.Y. jets..
eliptical done,,
foul, honey doo list....added sneak attack
back to regular stipulated programing soon..
dam you honey do list...........................
  #263 (permalink)
Old 02-04-2012, 12:00 PM
Last journal entry: Body work
Hey Bill,
White tank on left is for alcohol water injection system.
Luggage will go in the, not yet built, trailer.
Already have it set up for a receiver hitch and trailer wiring.
Thanks for the tip on the fitting unix, but all the fuel lines are just laying in place right now for quick pictures.
Damn!
Didn't get far on the short block this morning before problems.
First rod/piston assembly in and rod bolt hits the block.
This is a stock stroke motor but the rod bolts don't clear.
The rods are Eagle h beams with the L19 rod bolt upgrade.
No one informed me that there could be clearance issues.
I'm really pissed I have to take it all apart again to clearance the block.
Hope everyone Else's day is going better.
  #264 (permalink)
Old 02-04-2012, 12:04 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
sorry to hear that Ed,, but you know s&%t happens like that when you try stuffing a MONSTER MOUSE in a tiny shoebox,, not funny right at this moment HUH??
  #265 (permalink)
Old 02-04-2012, 01:07 PM
Irelands child's Avatar
Well, just over a week ago I started out with a simple, rear only brake job on my truck (it's an F350 4x4) to match the fronts done late last fall. Today, when finishing it up found one more dilemma. One of the hub bearings is shot. Now, so far:
A of Hawk LTS pads
Two new rotors - they're heavy suckas !!
Two reman calipers - these are beefy too
Two parking brake backing plates
Two sets of parking brake hardware
Two hoses (but will probably return them)
One expensive oil seal
One cup and cone inner bearing
Heck, I did engine overhauls for way less then this fiasco is going to cost.
I live in the rust belt
Irelands child
  #266 (permalink)
Old 02-04-2012, 02:42 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Don't you just love the snow and salt, eh?
  #267 (permalink)
Old 02-04-2012, 03:29 PM
It's called planned obsolescence - tho not MY plans
Irelands child
  #268 (permalink)
Old 02-04-2012, 03:49 PM
I don't know how you guys do it, man that is rough. I don't see rust like that on a fifty year old car, no kidding. Don't get me wrong, cars rust but it just isn't the same. My Windstar was from back east and you could see a BIG difference, it was not as old when I bought it as this Caravan I just replaced it with and the Caravan doesn't have a spec of rust on it.
  #269 (permalink)
Old 02-04-2012, 04:08 PM
Brian, after every snow flurry that leaves a coating on the roads, the highway department comes along and dumps the crunchy output of some salt mine - and the roads are white until it either rains or the next snow dump. That means the cars are white as well - regardless of the paint color. It IS a challenge. My 6 year old truck will be junk in another couple years without continued work - and at the price of even a 1 or 2 year old pre owned, repairs will continue until they can't be done any longer.
What's even worse, that salt is embedded in the road surface and every time it rains, more brine 24/7/365
Dave W
Irelands child
  #270 (permalink)
Old 02-04-2012, 05:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
No car stuff today but did get to use a few tools though, i did put a new dish washer in and the wife helped.
Cole
build thread, projects
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
