The "What Did You Work On Today" thread - Page 190 - Hot Rod Forum : Hotrodders Bulletin Board
  #2836 (permalink)
Old 03-18-2013, 12:12 AM
put up or shut up
since I blocked the fenders and doors on my mustang I decided to prime at least one side of the car. So I primed the L fender, L door, and L rocker. The
R door,R fender, and R rocker, will get primed tomorrow I hope. It's already masked up and waiting. The L fender looks ready!
you gotta love your gun when you can prime around those pieces of wood in the way without blotchy orange peel. Not me, that's the gun! Don't mind the fender alignment. I just slapped it on there to do body work.
  #2837 (permalink)
Old 03-18-2013, 08:00 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by 1971BB427 View Post
Just got home from the Roadster Show, and my little backyard built Austin gasser won "Best in Class" for the Nostalgia class at the show! Pretty pumped, as I didn't think it had a chance in a class with so many cars in it, and not being built in a fancy garage, or shop!
It is not the buildind ,it is the PERSON ,tech,,mechanic ,bodyman i,upolstrey ,etc etc, with a pashion and a dream ,your car shows your dedire,Good Job
  #2838 (permalink)
Old 03-18-2013, 09:02 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by sportcoupe View Post
Just finished putting in Aluminum panels in my rumble seat area to cover gas tank and wheel wells. Pretty happy with it. I polished the panels with a scotch bright pad on my small air cut off tool. Not sure if I need to spray some sort of clear on the panels or not. Kind of a pain in the butt if I had to polish them again. SC
Clear coat will work great on the polished aluminum. I got tired of trying to keep the intake scoop looking good on my T-bucket. So finally wet sanded it with 2000 grit and clear coated it, six coats from an aerosol can. Wet sanded it again with 2000 grit and buffed it out, Now it always looks good.
  #2839 (permalink)
Old 03-18-2013, 05:08 PM
Built Not Bought
Should have said Building ,i cnt type or spell,LOL
  #2840 (permalink)
Old 03-18-2013, 06:27 PM
78rubbernose's Avatar
65 mustang fast back
started stipping old bondo and paint. For Roger stevens srr wetsfiel nc.looong day
  #2841 (permalink)
Old 03-18-2013, 06:43 PM
1971BB427's Avatar
Hey I knew what you meant! Thanks!
  #2842 (permalink)
Old 03-18-2013, 06:50 PM
1971BB427's Avatar
Got back on the Falcon gasser project today. Pulled the wimpy Falcon 4 bolt rearend, and set the new 8.8" Ford rearend in place after cutting the perches off. Looks like it will be perfect for the Falcon. It's two inches wider, so it should be just the right amount of tire hanging out once I radius the fenderwells and put on 10" piecrust slicks.
  #2843 (permalink)
Old 03-18-2013, 09:31 PM
"Pie crust" slicks, I love it, never heard that term before and always search for the right word to describe them.
I worked on the transfer seat, things are looking good, right along with the plan from the beginning. I thought I was going to have to make some changes but I think it will work out. Only got a few more days before the Goodguys! double
  #2844 (permalink)
Old 03-19-2013, 04:20 AM
pics 65 mustang "get the led out"
stripped qp's roof ,trunk pan,and removed the lead from the seams
  #2845 (permalink)
Old 03-19-2013, 04:40 PM
mikesnyhere's Avatar
1957 3100 , the old generater works ! got more of the new wire harness in . put some new plug wires too , and timed it , dam she runs good ... big flat spot but then she pulls hard ! the accelerator pump failed , ive heard they are not compatible with new so called gasoline . this was a hygrade kit just so you guy's know . gotta flush the old brake fluid out , and adjust etc . btw 71 BB427 congats on the show win !. is the third your installing the explorer rear with disks posi and 411 gears ? that is a great junkyard part for hot rods ,
  #2846 (permalink)
Old 03-19-2013, 06:33 PM
1971BB427's Avatar
The 8.8" Ford I put under the Falcon project is a 3.73 posi unit, and you're right; they are a very good option! The equal to a 12 bolt posi GM, but a fraction of the price. Seems the word isn't out on them yet, so they're still affordable.
I went back to the wrecking yard today and picked up a 2wd Ranger driveline to shorten, and the spring plates for the Explorer rearend, so I can bolt it up.
The Following User Says Thank You to 1971BB427 For This Useful Post:
mikesnyhere (03-19-2013)
  #2847 (permalink)
Old 03-19-2013, 08:07 PM
Spent some time color sanding my doors today. One is done through 2000 and the other through 1500. With a little luck I will finish sanding them tomorrow and get them buffed tomorrow or Thursday.
I could get this done quicker if it weren't for sleeping late, taking naps, and going out to eat.
Life is good.
  #2848 (permalink)
Old 03-19-2013, 08:16 PM
bigdog7373's Avatar
Of course it's fast
Life is good.
Nothing to complain about there!
  #2849 (permalink)
Old 03-19-2013, 08:24 PM
1971BB427's Avatar
Life is good.
Ain't retirement great!
  #2850 (permalink)
Old 03-19-2013, 08:44 PM
Slammedsi's Avatar
Well this is what i worked on today. At just 5 days old he has taken most of my time for my truck. But that's just ok to me.
build thread, projects
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
Rodnit, 123pugsy, Dave57210
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
