The "What Did You Work On Today" thread - Page 200 - Hot Rod Forum : Hotrodders Bulletin Board
  #2986 (permalink)
Old 03-28-2013, 02:48 PM
I have never had a car that would even come close, not even anywhere near a dream of it even.
Could it be you are slipping Martha's clutch too much?
  #2987 (permalink)
Old 03-28-2013, 03:54 PM
That's Marge there John, don't insult my woman. Yeah, if I were to put a thousand pounds hanging off the rear bumper about fifteen feet I am thinking with side stepping the clutch at red line (about 2500 rpm) she may get the front tires off the ground.
  #2988 (permalink)
Old 03-28-2013, 07:07 PM
Or you could use a floor jack and a couple of jack stands!
BB
  #2989 (permalink)
Old 03-28-2013, 07:35 PM
Well crap BB, I have pulled a wheelie! You can't see me because the hood flew up, I'm right in there making vrrmmmm vrrrrmmm sounds.
Vrian
  #2990 (permalink)
Old 03-28-2013, 08:17 PM
Vrian
Now all you got to do is photoshop out the jack and stands and when your telling the story remember to say,"and then the hood flew up but luckily I can see through the window in the floor!"
BB
  #2991 (permalink)
Old 03-28-2013, 09:04 PM
1971BB427's Avatar
Vrian
The Falcon's been doing that same wheelie for a month now! Just coaxed it down this week, and I'm trying to talk nice to her so she wont get on her high horse again!
I got the fab work done for the Mazda steering box today. Had to relieve the frame for the gusset on the box to clear, and then fill it in. After that I sleeved the upper bolt through the frame with heavy wall tubing, and built a plate for the lower two bolts.
Ground the keyway out of the stock pitman arm so I could turn it 180 degrees. Ground the crimp out of the tapered jont on the pitman arm and gutted it. Then made up a filler bushing to accept my heim joint drag link, and welded the bushing into the end of the pitman arm.
  #2992 (permalink)
Old 03-28-2013, 11:09 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Blue printing a 383 (a 394 now) for the past week Trying to find needed parts I can get without waiting a month or driving a hundred miles to pick em up!
Almost complete now, just need the Mancini 8qt pan to come in. and the hardened oil pump drive, and fuel pump rod! And I can button it up and install it in a 66 Plymouth Fury. Man after a long winter I have to spring clean my garage LOL
Jester
http://www.hotrodders.com/forum/atta...=1364533692692
ID:	72679   Click image for larger version
ID:	72680   Click image for larger version
  #2993 (permalink)
Old 03-29-2013, 03:20 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
I found the misfire in my '68 Impala yesterday, bad plug wire on #8, so I pulled and regapped all the plugs from .035 to .050, put a new plug in #8 cylinder and put a new set of MSD wires on as I plan on hooking my CDI box up asap. I want to put it on today as the cruise-in is on Saturdays but I have to see how my body is gonna feel and act. Then, after I went in and ate lunch and took a 2 hour break, I went to the garage and finished pullin the motor and trans out of my '88 S10. I have never really believed in this Physical Theraphy stuff until I started it 6 weeks ago. It has really helped me! I have a PT come 2 times a week, just got approved for a 9wk. extension, and I have gone from losing all feeling from my waist down to walking with a cane again. I do my excercises every morning, takes about an hour and 45mins., and now I have hopes of going back to work one day. Alot of prayer and some will power seems to be all it takes. I didn't take any pictures of my Impala, I plan to today, but here are a couple of my motor out of my S10
  #2994 (permalink)
Old 03-29-2013, 10:58 AM
s10
Awesome to hear that you're up and about! I'm so happy for you! We are keeping you in our prayers and are hopeful for your complete recovery. I see you're getting things done over there...just dont over do it. Your mind is going 100 mph on these builds, but your body should obey the speed limit! LOL ...best wishes with your continued recovery and best of luck with your builds. Keep the pics coming.
  #2995 (permalink)
Old 03-29-2013, 11:23 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Jester
Great looking B block,,Beep Beep, did you do the art work,,
  #2996 (permalink)
Old 03-29-2013, 05:07 PM
That reminds me of a guy who asked one of my buddies if he could build a Y block ford engine that would turn 7000 rpms. I liked his answer. "sure once".
If you did all that Marge might pull those wheels one time.
  #2997 (permalink)
Old 03-29-2013, 06:11 PM
Built Not Bought
Received my Lokar shifter today ,also got my new gauges Classis Insturments installed ,and most of shifter installed ,still have to cut and install shift rod & boot .This install is not made for my hands,,tried to convince my wife her hands would fit better,She wasn't buying.LOL
  #2998 (permalink)
Old 03-29-2013, 07:18 PM
1971BB427's Avatar
We don't give them enough credit for being pretty darn smart! My wife never falls for that either!
  #2999 (permalink)
Old 03-29-2013, 07:58 PM
1971BB427's Avatar
My neighbor brought back my cherry picker today, so I made him stay and help me drop the engine into the Falcon. Then I cut out cardboard motor mounts and fabbed up the real ones from the templates.
The 454 is sitting on the new mounts, but they're just C clamped to the frame rails. Need to double check the measurements before welding it in solid, but then it's ready to weld in solid!
  #3000 (permalink)
Old 03-29-2013, 08:39 PM
327 / 350 hp's Avatar
What did u work on today
Holey moley BB that sure fills up the engine compartment !!! good luck jim
build thread, projects
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
MouseFink, luvbuildingcars, John long
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
