The "What Did You Work On Today" thread - Page 211 - Hot Rod Forum : Hotrodders Bulletin Board
  #3151 (permalink)
Old 04-13-2013, 01:00 PM
mikesnyhere's Avatar
Originally Posted by painted jester View Post
I haven't found any and my hands and fingers crack really bad And are pain full LOL When I was young it wasn't bad but with age the reducers and thinners tear em up!
Jester
they use a brand of glove when I work on the ship they take some serious abuse chemicals don't seem to hurt them .try to catch the brand next time im there . what about thickster seem to remember them being pretty good
  #3152 (permalink)
Old 04-13-2013, 01:22 PM
finally built a workbench , the materials were just laying around
  #3153 (permalink)
Old 04-13-2013, 01:26 PM
its not pretty or perfectly level but waaay better than the floor and drier !
  #3154 (permalink)
Old 04-13-2013, 01:47 PM
put up or shut up
Been sick all week and have been playing basketball everyday. I thought I was getting up today for my usual 9 am gym basketball pick up games but couldn't motivate myself to do so. I just ate some food and will drink lots of water and a little apple cider vinegar and go get my welding helmet down the street and come home and work on my car. The roof on this car is gonna be a cake walk. Apart from the prior damage in the quarter and very little rust here and there that I fixed, this car is in great condition. I guess I'm lucky to be in California cause it's stout as can be, almost like a brand new car. Really, it is. I was shocked the other night when I felt the roof. Very well maintained compared to some of the train wrecks I see at work.
Anywho, this car should be in the shop soon with some paint on it. Still got the exhaust and interior but it's moving right along.
Maybe tonight I'll make a video of some of the progress. Nothing better than listening to some good music and working in your garage at your own pace. If I want to take a nap on the job I can damn well do what I please!
  #3155 (permalink)
Old 04-13-2013, 04:47 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Been working on the seats and mounts in the '38. This is what it had when I got it. '83 Camaro seats and mounts. The mounts are different heights from driver to passenger and the PO put square tube "risers" under them to to get them high enough and even.
I replaced the foam and upholstery on the seats last fall and removed the fabric he had as "carpet". I then painted the base he made to blend with the carpet.
I then looked for different mounts to eliminate the risers and got a pair from an '87 Celebrity. They are much taller than the Camaro mounts so I had to back track and cut the base up and only use the low bar on the front. The outside rear bolt holes line right up with the frame so I can't get a bolt or nut in there. I welded a bolt to the pan to hold that position. I had to use a spacer between the mount and seat base to make up for the pan being lower on the outside too.
The mounts were rather rusty at the feet, so I ran them thru the blast cabinet and then coated them with Eastwood Rust Preventer. Next step is to paint them Gray.
  #3156 (permalink)
Old 04-13-2013, 05:24 PM
No way man, that is beautiful! Looks very solid which is so important. You just have to have a bench! I need to clear mine off so it looks like yours.
The Following User Says Thank You to MARTINSR For This Useful Post:
mikesnyhere (04-14-2013)
  #3157 (permalink)
Old 04-13-2013, 05:28 PM
Ditto! Work bench is a must. I have one...somewhere. Need to remember what it is under. I think it is on the back wall. Yes, that is correct. The wide stainless steel storage shelf is the work bench. I knew I had one.
John
The Following User Says Thank You to John long For This Useful Post:
  #3158 (permalink)
Old 04-13-2013, 05:29 PM
1971BB427's Avatar
It was a little too cool outside to do much on the Falcon gasser project, so I got some sheet aluminum and laid out the gauge panel insert. Cut the holes and the outside shape, then mounted the new gauges. Still need to pre wire it all for the dash lamps and turnsignal indicators.
  #3159 (permalink)
Old 04-13-2013, 05:32 PM
That came out awesome!
  #3160 (permalink)
Old 04-13-2013, 05:34 PM
Those are the fun part of building a car. The little projects that you can see and give that little shot of "accomplishment". Looks good.
John
  #3161 (permalink)
Old 04-13-2013, 05:40 PM
1971BB427's Avatar
Thanks John and Brian! Kept me out of the cold! I need to finish the framework for the steel tilt frontend, but I'm getting sidetracked. Need to ponder the job a bit longer!
  #3162 (permalink)
Old 04-14-2013, 02:18 AM
I have already filled my new workbench with stuff , work in progress . got my headlight relays working , and remembered the talk about period correct , listening to the oldies music and took this pic . not sure how old the sun equipment is but anolog gauges look the part ... playing with camera
  #3163 (permalink)
Old 04-14-2013, 02:33 AM
BB 427 that falcon has the look of a bad to the bone drag strip killer !!! ... greyscale . this is so original it still has clutch heads all over ! I don't have any of those tools yet . if I change the engine it would be simple , powerpak factory 4 brrl quadrojet and some early corvette valve covers . a lot of people say put an alternator in , pyt a Camaro front end etc . I like it just the way it is , even the steering and drum brake are getting better with adjustments .
  #3164 (permalink)
Old 04-14-2013, 03:00 AM
ok one more . you know the music from late 50's I know most of these songs , and still like them a lot ....coulnt you just see some cuffed 501's with some chuck taylors in this one !
  #3165 (permalink)
Old 04-14-2013, 03:54 AM
Docc's Avatar
Dry Heat
Last journal entry: along the weird tale..
I repaired or tried a repair on an old tank..needs to be welded on seam and bracket.. Better though..I found an NOS tank for $200..so..needed some minor alterations for gas line and mounting.. Tomorrow it goes in..
Glad I have bags..so I could raise it..enough to not need jack stands..
build thread, projects
Currently Active Users Viewing This Thread: 24 (1 members and 23 guests)
Edwin a. G
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
