The "What Did You Work On Today" thread - Page 214 - Hot Rod Forum : Hotrodders Bulletin Board
  #3196 (permalink)
Old 04-18-2013, 10:10 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Got a few more accesorys installed ,gave more room on steering shaft ,about an inch additional ,added a Tach ,Also an Original air filter has some pitting but it does not look as bad as the picture and for the cost of a replacement ,I will have to run it for now,
ID:	73307   Click image for larger version
ID:	73308   Click image for larger version
ID:	73309   Click image for larger version
  #3197 (permalink)
Old 04-18-2013, 10:16 PM
1971BB427's Avatar
Looks fantastic! Love BBC power!
  #3198 (permalink)
Old 04-18-2013, 10:20 PM
1971BB427's Avatar
Picked up my new slicks from Hurst Racing Rubber today! Got them mounted up, and then came home and chopped up my wheelwells!
Then I played with fitting my Mercedes front fender lips to the top edge to finish off the openings:
  #3199 (permalink)
Old 04-18-2013, 10:36 PM
BOBCRMAN@aol.com's Avatar
NASTY weather today!
Power was out most of the day. Ran generator. Painted the fuel tank with a couple of spray bombs and cleaned/bead blasted/checked the sending unit.
My new BOBcam CAD-CAM discs came today so I watched the basics/setups. Now I will have to finish the CNC plasma table I started during the winter.. Those programs are good but not cheap!
  #3200 (permalink)
Old 04-18-2013, 10:39 PM
Built Not Bought
Can you run the tires without John Law on your case, those flares are going to look great will clear body moulding if you leave it on .I would.I have a MGB convertible I probable will be running an LS engine in it ,I looked at another MG with Dodge Omni or Plymouth horizon fender flares cut about 5 in above fender lip they flared out about 3 in,looked Good on it ,don't know how they eould look on something else ,,
  #3201 (permalink)
Old 04-18-2013, 10:51 PM
1971BB427's Avatar
We are lucky here with hotrods and the laws. In the late 1990's Oregon passed hotrod law legislation that exempts many cars that fall into the hotrod classification from certain rules that daily drivers have. Since this car is licensed with permanent "special use" original year 1963 plates, the law wont bother me. At least if I'm driving sanely, and not acting like an idiot.
  #3202 (permalink)
Old 04-19-2013, 04:06 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
Looks great!! You have got the correct breather and could even have it rechromed when money permits. New stickers and you're in like flin.
  #3203 (permalink)
Old 04-19-2013, 06:52 AM
Built Not Bought
Thanks, I am going to check on rechrome if they can do the top side only ,cant chrome the bottom side as it has the AC logo and numbers stamped there,it wold destroy the value if they were covered ,This engine will go back in my 66 Chevelle SS probably 2 yrs, after I get the new engine built for my truck,i am running in truck to keep it loosened up,I have a Weiand 671 blower and a Vintage Crager 671 blower to go on my new engine for the truck,still need to find an 671 intake would like to find a used one for the Crager to match the look,or a polished for the Weiand. where is mascot what bigger town close.
  #3204 (permalink)
Old 04-19-2013, 07:39 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Rechroming the cover would involve dipping it in a solution to disolve the existing chrome. Obviously, no decal will survive that...
Shoulda put the preformed by-pass hose on before bolting up the intake or water pump. They can be a bear to squeeze on now......not that I would have any experience with that.....
  #3205 (permalink)
Old 04-19-2013, 07:46 AM
I spent more time finishing the seat mount install and painting them.
Then I turned to initial mock-up of the Vintage Air evap location. I've already cut and welded one of the brackets to clear the cowl vent drain tube and fabbed another across the front to locate that support brace away from other things. I know it's a "universal" case but not very well thought out, in my self-centered opinion... I need to look in the hose kit box to see if they include any form of bulkhead accomodation or if I need to get a bulkhead plate for all the hoses to pass thru.
I took a couple pics but will wait till I get a few more to explain my thoughts on the bracket relocations. The new blanket of snow is making it hard to get excited about hot rods right now...
  #3206 (permalink)
Old 04-19-2013, 08:00 AM
Built Not Bought
Yea yhat hose can be a problem ,I bought a pre formed hose from Ecklers Corvette should go on eaiser, i normaly take a piece of 3/4 hose 4,5/8 in long,it works fairly easy if you put it in hot water first,,i was not worried about decal but underneath the lid the metal is stamped from the factory with an part # and AC Delco I don't want covered up,i can buy a repo but don't want one of those Chinese chrome jobs,,i have been rushing to try to get mine finished by July, I forgot to leave holes for my Vintage Air,
  #3207 (permalink)
Old 04-19-2013, 09:28 AM
1971BB427's Avatar
I've never had much trouble with that hose on a long water pump, but a short pump is impossible!
  #3208 (permalink)
Old 04-19-2013, 10:33 AM
Remove one of the nipples, apply a tiny bit of lube to it, slip the hose on and tighten the nipple by rotating in the hose.
  #3209 (permalink)
Old 04-19-2013, 05:30 PM
Built Not Bought
Installed dash trim and several other parts today.Still like a few parts.LOL now I need to find a banjo sterring wheel,
ID:	73320   Click image for larger version
  #3210 (permalink)
Old 04-19-2013, 06:09 PM
Another cold, wet, windy, nasty day.
Made two lifting fixtures from old square tubing. Bolt to firewall and another behind rear window. So I can remove body from frame with cherry picker.
Lifted body up about an inch on front . Found a hidden body mount bolt that will have to be removed. Wind was shaking the building and rain was making so much noise on the metal roof that I couldn't hear the radio. so I closed up early
build thread, projects
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
