The "What Did You Work On Today" thread - Page 220 - Hot Rod Forum : Hotrodders Bulletin Board
  #3286 (permalink)
Old 04-26-2013, 09:18 AM
I just don't get why it comes and goes, this is the same gas that has been in the tank from before I parked her.
  #3287 (permalink)
Old 04-26-2013, 09:25 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Have you checked fuel pressure on outlet side and vacuum on intake side of fuel pump,,on a sbc the vacuum side is around 4 lbs ,I am guessing Marges should be the same or close.
  #3288 (permalink)
Old 04-26-2013, 10:27 AM
I don't have a gauge to do it, so no I have not. I did run a hose into a can from the pump and ran the motor for about 10 seconds giving her a few med revs and it pumped about a half a pint of fuel. That is the only test I have done. I need to check the pressure, that friggin rebuilt pump may be it. The vacuum side doesn't work properly as the wipers still slow at throttle so there certainly could be something wrong with the pump it's self.
  #3289 (permalink)
Old 04-26-2013, 10:50 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
And THAT just may be the issue. Ethynol blended fuel needs to be agitated to keep the corn squeezin's suspended. By letting a car sit, for as little as a week, lets the ethynol start to settle to the bottom of the tank. If Sea Foam is available in CA, add a can of it to the tank and drive the car.
  #3290 (permalink)
Old 04-26-2013, 03:53 PM
Barb and I are both in bed with very sore throats. The car is back together but between the sore throat and the lousy weather forcast I believe the Cleveland cruise in is out the window. Bummer.
  #3291 (permalink)
Old 04-26-2013, 04:25 PM
Built Not Bought
Sorryto hear that ,Both of you GWS,we will say a word.
  #3292 (permalink)
Old 04-26-2013, 06:45 PM
I appreciate that. The throat is better today but it is moving into both of our chests. Beginning to cough. Some things you just have to wear out. My health issues are minor compared to some others.
  #3293 (permalink)
Old 04-26-2013, 09:24 PM
Built Not Bought
Just got finished removing the tines on the tiller of my tractor will have to go get I new one omorrow ,I have one missing, I used the snake oil mix I posted a couple weeks ago it worked on all but I bolt,1/2 " grade 8 bolts it has ben outside in the weather for about 12 years,was using a 4ft cheater bar, finally cut the heads off with a 4 in grinder, well the snake oil works Most of the time,LOL
  #3294 (permalink)
Old 04-26-2013, 09:29 PM
Built Not Bought
I will go lower tonight ,for well know the lower we go ,the higher we can reach..
  #3295 (permalink)
Old 04-27-2013, 04:55 PM
Last journal entry: 41 chevy frame on the move.
Here is what got accomplished today.I finished drilling and bolting togther my car rotisserie and it actually spins!!! YAAAA Now I have to take it apart,clean all the peices and prep for paint.
stefanP
Name:	WORK CAR ROTISSORI 013.JPG
ID:	73601   Click image for larger version
Name:	WORK CAR ROTISSORI 015.JPG
ID:	73602   Click image for larger version
Name:	WORK CAR ROTISSORI 014.JPG
  #3296 (permalink)
Old 04-27-2013, 06:03 PM
BOBCRMAN@aol.com's Avatar
A good weather day at last. More grinding, blasting and got a little primer on frame after rolling it upright. Front leaf spring brackets mounted and springs hung on one end. I still need to make front spring shackle frame mounts. Fitted side motor mounts. Started fitting an under floor mounted modern master cyl. Not much room under there.
  #3297 (permalink)
Old 04-28-2013, 07:07 PM
Nuther wet drizzly day. My road is starting to look like those old model "T" bad road muck/mire shots from the late twenties.
This afternoon I grabbed some square tube and a piece of 1/2" thick wall pipe and made up two spring shackle to frame mounts.
All this wet weather is causing problems with my air system. Plasma cutters and moist air don't work well together.
Bolted the spring/shackle/mount assembly to frame about 5 pm.
  #3298 (permalink)
Old 04-28-2013, 08:32 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Just to be clear that TIG gloves IS what I have being I have never TIGed in my life, here are my gloves and the difference. Click on the photo below to see a video.
Brian, Those TIG gloves are the exact same as what I have. I have also never had a TIG gun in my hand, but I sure do like the gloves. I weld mostly with 3/32" 7018 stick rod, and they are fine for that, as well as when I use my buddy's wire feed. Always use them grinding also. Sure saves on the shirt sleeves. Allan
The Following User Says Thank You to adantessr For This Useful Post:
MARTINSR (04-28-2013)
  #3299 (permalink)
Old 04-29-2013, 11:27 AM
1971BB427's Avatar
Got the Falcon's trunk cleaned, wire wheeled, and painted. Then did a small rust repair on the lower trunk drop. Patched in a 1.5"x8" piece, as it was easier than cleaning and welding in the 8-10 small holes there. Then I traced out some blank off plates on scrap aluminum and cut them out with a jigsaw for my rear wheels.
And got a big surprise when I got up early Sun. morning! Some dirtbag had appraently tried to steal my '69 Suburban! I hit the alarm off button, and no beep. Hit it again, and nothing. Then I noticed the hood open about 8", and when I opened it up the battery pos. cable was off. Seems they tried to get around the alarm, but it goes into full alarm everytime you reconnect the battery, so they gave up and left.
I reconnected and silenced the alarm, then when I got home later I drilled the inner hood brace and added a chain and padlock to keep the dirtbags from getting the hood open next time.
  #3300 (permalink)
Old 04-29-2013, 12:29 PM
Built Not Bought
You did a good job on the centers ,I remember those on the Ansen and some Torque thrusters.nice vintage look.
build thread, projects
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
