The "What Did You Work On Today" thread - Page 229 - Hot Rod Forum : Hotrodders Bulletin Board
  #3421 (permalink)
Old 05-08-2013, 10:58 AM
put up or shut up
today I get to fabricate some bottom pieces to a pick up bed. Boss wants me to match what's under the cab. What pisses me off is how and tbe he hell am I supposed to fab this up? We have NO metal fab tools and I've been asking for a vise for like a YEAR!!! The pieces aren't very long, about 24". Before and after wheel opening. So I can make for instance a 25" piece and fold 1/2" on each side for the jamb and then use the shrinker or stretcher to get my shape. I think that would be the easiest way, and while I'm at it to make traces of each piece for the other side, including contour with the contour gauge. I think it will be fun but I need a vise and to possibly shape up some wood for certain areas to hammer form, cause that's the poor man's way of doing it with the limited tooling as of now. Wish me luck.
edit:just called the boss and they're getting the vise and shrinker. YES!
  #3422 (permalink)
Old 05-09-2013, 12:16 AM
put up or shut up
so the boss gets a shrinker/stretcher from HF and because they didn't have any boxes on display the kid had to go to the back to get them. I guess they ship 2 boxes in a box cause we got TWO SETS in a box for the price of one. So I'll split the cost with my boss and give him $75 for a set. That worked out well.
As far as the work I'm going over, it baffles me...somebody actually designed the thing pretty good but welded it really badly. So I'm going over some welds and cutting some areas out and starting over. Tomorrow I get the shrinker/stretcher mounted to the vise and get started fabricating that little area behind the wheel on the bed.
Highlight of the day...getting home and seeing my daughter playing in the front yard and my new $75 shrinker/stretcher kit....oh, and The Warriors beat them old men called The Spurs! YES!
  #3423 (permalink)
Old 05-09-2013, 06:29 AM
deadbodyman's Avatar
Wiki Edits: 11
Tech,Are the two different colors???? one is the shrinker and one is the strecher..Wear a glove when using them ,the handle will put one hellofa blister in your palm...
Your on your way NOW!!! have fun with it...
Heres a pic of mine (in the back ground)at the left of the tool box one is yellow and one is black. to get the most out of them you really need a foot operated stand...this stand works great ,you could make one but this works and is well worth the money...even with free labor its cheaper to buy than build, the steel will cost more than the unit...
  #3424 (permalink)
Old 05-09-2013, 06:34 AM
Last journal entry: door trim
car show
went to my first car show of the season here in Maine with my car. All legal and inspected as a streetrod. Nice sunny day at the local high school parking lot. about 400 cars, trucks, motor cycles and anything else with a motor and wheels. Nice to finally have my own car at the show.
  #3425 (permalink)
Old 05-09-2013, 08:23 AM
1971BB427's Avatar
Got my 6 pt. rollbar knocked out yesterday. Had a little time leftover, so a friend came over and we bent up a 4 pt. for his '56 Chevy street gasser too. Didn't get time to weeld his up, but maybe next week.
  #3426 (permalink)
Old 05-09-2013, 08:30 AM
That is looking so cool! The only thing I got done yesterday was that I was handed $100 from a friend for helping him (he always does that, has TONS of money and always does that no matter what I say) so I have my money for the 49-54 front end I am going to go get next weekend. Of course once I get it, it won't be a 49-54 Chevy Passenger car front end anymore, it will be a 53-62 Corvette front end.
But that is the only thing I did with any of my projects yesterday or the weeks before. I just haven't been able to get out there darn it!
  #3427 (permalink)
Old 05-09-2013, 08:37 AM
put up or shut up
yes, 4 bodies in all. 2 yellow and 2 black. I knew it right away as soon as he opened the shipping box cause I've seen the boxes on display.Still need some other metal working tools but I'd rather get the paint for my car soon. well, it's a good start on a pretty simple project, or at least it seems simple.
  #3428 (permalink)
Old 05-09-2013, 04:29 PM
1971BB427's Avatar
After a lot of head scratching, and a lot of fab work, plus some modifications, I finally got the gilmer belt system mocked up. Definitely not a bolt in thing, and luckily I had a $5 swap meet alternator bracket that I reworked to fit.
Then I punched a bunch of holes in the axle with a holesaw and lots of Rapid Tap. Got all 11 drilled with one bit!!!!
Finally cleaned up the front floor pans and painted them too. So shiny the camera didn't want to focus, or it was high on fumes!
  #3429 (permalink)
Old 05-09-2013, 04:54 PM
One of my friends on the Ford Barn was kind enough to print and send a timing tape calibrated for my Flattie. Now I will be able to set my distributor up and not just set the initial timing.
The Chevy distributor is able to run close to 40 degrees of total advance but the flathead can only stand about 26 degrees. Having the tape is going to really make it easy to see what the distributor is putting out for initial, mechanical, and total advance. I hope to play with it some tomorrow.
Thanks Richard in Florida.
  #3430 (permalink)
Old 05-09-2013, 05:02 PM
1971BB427's Avatar
I put them on everything I own! Summit sells them based on balancer diameter for about $3, so hard not to have them. They're such a great aid in tuning!
  #3431 (permalink)
Old 05-09-2013, 05:16 PM
I can see that. I borrowed a Craftsman timing light that has the dial which allows you to use just use the one timing mark but I kept getting conflicting readings. The concern is the circuitry of the timing light is causing issues. Now I can use just a plain old timing light and not have to wonder.
The guys on the Ford Barn who have spent a lot of time playing with the SBC distributors say 20 degrees of mechanical and 6 degrees of vacuum are ideal for the flathead. I believe this distributor is set very close to the 20 degrees mechanical but I also believe it is giving me 10 or 12 degrees of vacuum advance. It tends to pull well at full throttle but ping under a light pull. I should know what I have for sure in a day or two.
John
  #3432 (permalink)
Old 05-09-2013, 05:27 PM
1971BB427's Avatar
I tried one of those modern timing lights with adjustment for dialing in advance, but didn't like it. I went back to my old school timing light, and it does the job well for me.
The Following User Says Thank You to 1971BB427 For This Useful Post:
John long (05-09-2013)
  #3433 (permalink)
Old 05-09-2013, 05:56 PM
BOBCRMAN@aol.com's Avatar
Got only a couple of hours on the Stude frame. More grinding. Got a little more primer on it. About 3/4 ths done on paint prep.
My universal parking brake cable kit came today. So I guess I will get that fabbed in after the frame gets painted.. Race car with a working parking brake!!
  #3434 (permalink)
Old 05-09-2013, 07:00 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
You are a craftsman ,great work Thumbs up for the Nostalgia look ma be my next project,
  #3435 (permalink)
Old 05-09-2013, 07:05 PM
1971BB427's Avatar
Thanks a lot! You'd have laughed if you saw how I cut the 1/2" off the back of the alternator pulley, but it worked! I put the back of the pulley on my portaband saw and turned the pulley as I cut. The back step kept the saw blade aligned, and turning made a nice smooth cut. So after cutting it I didn't even have to dress it off. Put it on the alternator and checked it by spinning and it was perfectly true!
build thread, projects
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
