The "What Did You Work On Today" thread - Page 248 - Hot Rod Forum : Hotrodders Bulletin Board
  #3706 (permalink)
Old 05-31-2013, 06:07 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I have been working about 5 hours to correct a mistake I will not make again,i taped up my car to spray the epoxy primer about two weeks ago.since it is a convertible i left it taped up to block it and not get snadind dust on my top and interior,,Yes it was 3M ,never had this to stick like this comes of in pieces about the size of a quarter ,the big pieces about 2 in long.
John if you change to a V8 I have a 305 and a 700 od Cheap ,mighy consider sellig the 327 we talked about ,,327/300 still in plastic never ben put together it is a 66 engine 461 double hump heads cast iron holley intake 2-1/2 ram horn manifolds dual point dist ,I would have to think on price of it,
This the engine and trans I took out of my 53 to install the big block.
Name:	chevy engine and od trans 001.jpg
  #3707 (permalink)
Old 05-31-2013, 07:39 PM
Built Not Bought
Brian,is your truck a 5 window or a 3 window.
  #3708 (permalink)
Old 05-31-2013, 09:02 PM
I really appreciate you thinking of me. I will certainly remember you have them. Right now I am going to budget my money for rust repair. It remains to be seen whether I can form the braces and floor pans ornwhether Imam goingmto spend 3000 dollars for reproduction sheet metal. I would be happy with a good 305 but Imdo want a clutch pedal. That rebuilt Muncie I have is just bagging to be in there. Of course if I used the 305 I could save the Muncie and use the Saginaw I have......or mabe a 5 speed. Wow! there are so many possibilities.
  #3709 (permalink)
Old 05-31-2013, 09:29 PM
Funny you should ask, it's a five window, but I have a three window roof that I was going to use to make it a three window. But now with the Motorama theme it will remain the five window and in fact I will be making the center window larger.
  #3710 (permalink)
Old 05-31-2013, 09:39 PM
Looks like the new owner of the vette will do it some good. I have a question about the forum. I made a thread asking about paint/processes for household paint. Did I put it in the wrong section and it got deleted? I didnt know where to put it it was a 50/50 with the general tech or general rodding. I was asking advice here because im sure most of the members here have had experience with doing so. I guess I made someone mad.
  #3711 (permalink)
Old 05-31-2013, 09:54 PM
I have no idea where it went but it should have been posted in the body section.
  #3712 (permalink)
Old 05-31-2013, 10:32 PM
Well it involves actual home walls...im having major issues with the bathroom with it cracking and flaking. It will only last 3 months tops before it starts cracking again. Ive thought about a poly sealer but I want it to be flat white not sure if it would settle into the paint to maintain the flat white look
  #3713 (permalink)
Old 06-01-2013, 06:21 AM
Built Not Bought
The 5 speed sounds better ,I have a Saginaw and a Borg Warner both 4 speeds ,starting to get hard to come by around here if you don't use the Muncie I would be interested in buying it,
  #3714 (permalink)
Old 06-01-2013, 06:31 AM
Built Not Bought
Brian I noticed you said you needed some things for your truck ,I have a 53 =5 window and a 50 -3 window I will have a lots of parts left ,,,,the 50 has ben restored before I bought it ,I will be taking off lots of parts I will be chamging to a street rod I am putting it on a 86 corvette chassis complete. for my wife, the 53 ,I have all the rubber for the windows ,less than a month old ,I replaced it ,then took it back out and replaced with the rubber that has the stainless in it ,I have the gauges ,all work but will have to replace the needle on speedometer ,mirrors ,handles inside and out door latches etc etc,to much to list here ,I will send you what you need.or want
  #3715 (permalink)
Old 06-01-2013, 06:59 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
John, I am with ya on the '54 taillights and such. '54 is my favorite year of pre-tri fives.
A 5 speed would be a good addition....better gearing, mileage and one more throw of the lever.... I'm a manual man myself.
I have a vintage 283 that was running when pulled several years ago. I'm sure it needs refreshing and we're a LONG way apart but I have it on craigslist. It was going to go in my '52 flat bed but I'm leaning towards a 292 right now to keep it a 6 cylinder.
This internet stuff is fun by bringing people from all over the country/world into our homes but when it comes to meeting or helping, you realize the distances between.
  #3716 (permalink)
Old 06-01-2013, 07:19 AM
If it's about walls in your home post it in "off topic". I personally know next to nothing about house paint. But with my very limited experience it sounds like you have some moisture problem and it may require striping it all off, it sounds like you could have mildew or something in the sheet rock. Removing it may be the only answer.
  #3717 (permalink)
Old 06-01-2013, 07:21 AM
I could be interested in the rubber, I actually think I have some, I believe I have all "new" that I bought about 20 years ago! Believe it or not, I have an NOS windshield rubber I bought from the Chevy dealer!
But then again, I am thinking about going with the stainless too. The seat is about all I may need, but I may go with a car one.
Right now, I think I am good, thanks so much.
  #3718 (permalink)
Old 06-01-2013, 07:32 AM
Built Not Bought
I have a perfect seat with new repo cover ,but the freight would be more than the seat is worth, if you decide you need any thing let me know I will send it to you.
  #3719 (permalink)
Old 06-01-2013, 07:36 AM
Built Not Bought
Thought you might get a kick out of this,LOL
ID:	74469   Click image for larger version
ID:	74470   Click image for larger version
ID:	74471   Click image for larger version
ID:	74472   Click image for larger version
Name:	1953 Belair Conv.jpg
  #3720 (permalink)
Old 06-01-2013, 07:43 AM
Finishing up getting my Pete ready for market. Needed new brakes on the rear drive axle.
The dust shield was rusted away too
New shoes, hardware and dust shield.
And new AMERICAN made drums...
I take it to get steam de-greased on Monday and then it goes on-line...
build thread, projects
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
