The "What Did You Work On Today" thread - Page 260 - Hot Rod Forum : Hotrodders Bulletin Board
  #3886 (permalink)
Old 06-09-2013, 08:59 AM
Mike, I will be doing some welding with my Jewelers torch and posting it, this thing will blow you away.
I don't believe the wire is what makes the weld so hard, I believe it's the way it is used, the whole electrons and all. At least I believe so, but I believe that to be the true. I believe they cool so fast the molecules gather making them harder.
On the clothes hangers, they are very soft metal and they are coated with a "paint" to keep them from rusting, so there is a big difference between them and the welding rods bought at the welding supply. I won't be using coat hangers anymore!
  #3887 (permalink)
Old 06-09-2013, 09:11 AM
Originally Posted by 1971BB427 View Post
I'll have to look into that jeweler's torch Brian. That's pretty cool. And the MIG wire is a good idea too.
I have only used it a little bit as I bought it before I went back to work on the line and stopped all my projects at home. I butt welded the quarter patch panel on the Gran Sport with it, I am not kidding you can really do some neat stuff, a TINY little weld bead. This is with the largest tip in the kit, with the smallest you can solder on a circuit board!
  #3888 (permalink)
Old 06-09-2013, 09:22 AM
deadbodyman's Avatar
Wiki Edits: 11
Burn the varnish /paint off first with the torch ??????
  #3889 (permalink)
Old 06-09-2013, 09:28 AM
Nope, I will buy welding rods at the store. This is sort of like using paint thinner from the McHome store as wax and grease remover.........I just don't think the 14 cents savings is enough to go thru the trouble and the gamble.
  #3890 (permalink)
Old 06-09-2013, 10:25 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Wouldnt that depand on the rod your using, puggs...with mig wire I would think the weld would be a little hard (like a mig weld) but I havent gas welded any sheetmetal since the 70's I was never any good at it so the mig was my saviour. and it wasnt the tip size because I couldnt even gas weld muffler pipe ...so all I use my torches for is cutting heavy stuff and heating metal for forming.
..............A mans gotta know his limitations.......Clint E.
As Brian mentioned, it's not the rod but the process that makes the MIG weld "crispy".
About the jewelers torch; is it big enough to give good penetration in sheet metal?
  #3891 (permalink)
Old 06-09-2013, 12:58 PM
Yep, with a butt weld and using .023 wire you put a little 1/16-3/32" wide bead.
  #3892 (permalink)
Old 06-09-2013, 03:27 PM
Originally Posted by Too Many Projects View Post
They had a set of various wooden blocks and wedges and just bent whatever didn't match until it did. Once in a while they would loosen a bolt but most of it was just done with the blocks and bending.
They used to do that all the time at Winnebago. If the inspector was nearby, they might cut a floor loose and re-weld it; but most of the time, it was a block of wood and a sledge
  #3893 (permalink)
Old 06-09-2013, 06:26 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Friday and Saturday was spent de-greasing, aluminum cleaning and washing the Pete for pics.
Today I had a little time so I installed a new door panel in the '52. I got them from Jim Carters Truck parts. I got new foam spacers and cardboard washers too for the handles and all new screws and washers to mount the board.
Before..
The cardboard is only painted on one side and they recommended painting the back to prevent moisture absorbsion and separating. I sprayed a coat of matte clear on to seal them.
I wasn't sure what the original color was and thought it looked Burgundy. I got light Gray to match the headliner I have.
Foam and cardboard spacers to keep the handles from rattling.
  #3894 (permalink)
Old 06-09-2013, 06:29 PM
DAMN that truck is in nice shape!
  #3895 (permalink)
Old 06-09-2013, 09:14 PM
Wiki Edits: 11
yeah probably wouldnt make much difference with my gas welding ...mabee i'll get one of those jeweler torches and give it another try...
  #3896 (permalink)
Old 06-09-2013, 09:26 PM
1971BB427's Avatar
It's been many years since I used an oxy-acetylene torch to weld, although I sure enjoyed it when I did. I just seem to have gotten to using the Miller MIG for everything, even when I know some things could be easier with the torch. I need to probably practice a lot to get back in stride with the torch!
  #3897 (permalink)
Old 06-09-2013, 09:29 PM
In the old days hangers were pretty good metal. Over the years they became mostly recycled metal and looked like sparklers when you used them. In this day and time it would be foolish to use anything but good CC rods.
John
  #3898 (permalink)
Old 06-09-2013, 09:37 PM
Before you go spend any hard earned money let me get back to you being I haven't used mine much, just the few times it was awesome.
  #3899 (permalink)
Old 06-10-2013, 12:13 AM
Today I got up and went to a Chili cook off with the wife and my daughter, and I have to tell you, I enjoy this event every year and today was no different.
So with that and doing some work on the house, not a whole lot got done. But I did clean up the garage to be able to move the cab inside. I also decided to weld the jack-stands to the cart for the cab, looking out side this morning seeing it on the jack-stands gave me the willies.
So I cut the top of the jack-stands off so it could remove them if I want and welded the top on to the frame. The bottoms were already modified for a project years ago. It was funny that I set up the rear axle without any planning on if the front stands would need any work to make it perfectly level. But right there on the first hole it was perfect.
I also put the motor in front of the cab just to make it feel better.
  #3900 (permalink)
Old 06-10-2013, 12:38 AM
Project89's Avatar
Yes, a tweaked hood is a whole different animal. Good luck.
John
i got it close picture didnt come out though.
its the hood itself on the driver side its even were the hinge is , then twards the center of the hood moving foward its high, and just at the front over the headlight pocket its slightly low
put a block of wood under the front of the hood and just infront of the hinges and slowly applied pressure and got it much closer. lil more working it and i think it will line right back up. tomorrow when i get out of work im going to work on it a lil more
build thread, projects
Currently Active Users Viewing This Thread: 9 (1 members and 8 guests)
496CHEVY3100
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
